Radio wire ID
Old Jan 26, 2007 | 11:36 PM
Crab's Avatar
Crab
Default Radio wire ID
I'm trying to put a stock GM radio/ 8-track back into an 80 dash after someone bubbaed the original wiring by cutting off the old plugs and pulling and splicing into the wiring harness. Can anyone tell me what the 2 yellow wires are for. Car is equipped with power ant. but at this point I'm not sure it even works properly. If you can ID all 8 wires that would be great.
Old Jan 26, 2007 | 11:55 PM
SIXFOOTER's Avatar
SIXFOOTER
One is power from the fuse panel, the other goes to the antenna relay
Old Jan 27, 2007 | 12:02 AM
Crab's Avatar
Crab
Is the relay in the rear compartment behind the passenger seat?
Old Jan 27, 2007 | 12:18 AM
SIXFOOTER's Avatar
SIXFOOTER
The pic isn't very good but the description says Rear Center Console. Looks like it might be behind the seat
Old Jan 27, 2007 | 12:40 AM
Big2Bird's Avatar
Big2Bird
Yep
Old Jan 27, 2007 | 12:48 AM
TimAT's Avatar
TimAT
The gray wire will be the panel lights. The speakers will be paired wires, blue/black, green/black. Some radios had lthe pins identified on the case. Black is ground.
Old Jan 27, 2007 | 08:16 AM
Crab's Avatar
Crab
I've got 1 white plug with 2 wires ,1 brown and 1 gray.
The other plug is blue with 1wire lite blue and 1 wire dark blue.
Are these the speaker wires and does each speaker get a seperate ground?
This is a BIG help, that dash looked like a bowl of spagetti when I got the car.
Old Jan 27, 2007 | 12:06 PM
TimAT's Avatar
TimAT
Each speaker has it's own ground back to the radio. To find out which is which, take an ohmmeter and connect it to each lead. Process of elimination will get you which 2 wires go to each speaker.
I'd bet the plug with the gray wire is lights. Setup your meter for volts, red to the gray and ground the black one. Turn on the headlights and watch the voltage change when you dim the panel.
The blue one will likely be speakers.
Old Jan 27, 2007 | 12:07 PM
Crab's Avatar
Crab
Anymore help? Do I need to ground each speaker,or does the ground come through the radio ground?
Old Jan 27, 2007 | 12:16 PM
Glassbowtie77's Avatar
Glassbowtie77
Would this be easier perhaps? http://www.zip-products.com/Zip/dept...7079BAC18434F6
Old Jan 27, 2007 | 12:27 PM
Crab's Avatar
Crab
Yep, your right the gray wire on the white plug is for lights.
The other two plugs are missing from the wiring harness itself.
I've got 2 plugs with the radio I got from ebay that I'm trying to make work. After pulling up some of the carpet, I find there are no rear speakers or original speaker wire. That's probably better anyway to just run new wire. Thanks for all the help
Old Jan 27, 2007 | 12:41 PM
Crab's Avatar
Crab
Originally Posted by supervette77
Much easier,yes I think it is worth a look for sure. Thanks!!!!!
To Radio wire ID
