Engine Cooling Perfection Achieved
Old Feb 5, 2007 | 07:59 PM
  #41
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Nice work Photovette. I am very intrigued by the Mark VIII fan setup and you guys have done nice work documenting the work and results. Thanks for posting the pics. Those will come in handy oneday.
Old Feb 5, 2007 | 08:02 PM
  #42
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
i don't get why everyone thinks the electric fans are the *****. I don't like the whole concept that they won't come on until the rad hits 160/180 or whatever. Whatever thermal reserve you would have had is lost.
With a mechanical fan the air is pulled thru all the time keeping the radiator as cool as possible at all times allowing considerable thermal reserve capacity that will be needed for WOT operational bursts.
I'm of the opinion that fans need to run all the time with these cars because of the small frontal area. A negative pressure area sure helps things when at highway speeds.
With your system you will probably never see any deficiencies because it is more than anyone needs for cruising around. But when really running hard for long periods you could see some temp spikes. My sysem with a 2 row 1.25" tube aluminum radiator and mechanical fan i have been unable to exceed 190 at Mosport which has big straighaways. You won't see higher duty than that other than maybe towing a trailer in the mountains.
Old Feb 5, 2007 | 09:59 PM
  #43
Kid Vette's Avatar
Kid Vette
Not to hijack the thread but I am skeptical of the value of an electric fan also. I just can't believe its worth the expense and bother. Just my 2 cents
Old Feb 5, 2007 | 10:06 PM
  #44
Durango_Boy's Avatar
Durango_Boy
Sometimes it's needed. I have a long water pump being installed along with the new belt system, and you cannot use a mechanical fan.
I got the car with a mechanical fan installed, and everything was working properly. The car would exceed over 200 F at idle, and anything over 50 MPH. I installed an electric and I had 190 from idle all the way up to extended periods at 70 MPH. I had to switch back to mechanical when the fan I was using burned up two SI alts in a row.
I'm going back to electric, but this time with a better charging system, and a better controller.
Old Feb 6, 2007 | 10:39 AM
  #45
Kid Vette's Avatar
Kid Vette
As far as I know 200 F is considered normal operating temperature.
That's exactly what I'm talking about. By the time you switch alternators and buy a controller and all the other stuff you need you will have a ton of money and effort tied up in something that IMHO gives you very little in return. Same goes for serpentine belt systems IMHO. But its your money and time, if its something you want to do its cool.
Old Feb 6, 2007 | 10:41 AM
  #46
BerniesVette's Avatar
BerniesVette
It seems that the car manufacturers went exclusively to electric fans so that cars will warm up sooner. Using computer controllers and relays the temps are better maintained with less spikes in temps than conventional systems. Also saves a few horses as well. Engine driven fans are not as efficient at low speed/low engine rpm conditions; exactly when they need to be most efficient. My C3 runs cooler at 100 MPH than at 20 MPH because the fan is bearly turning at 20 MPH. Electric fans aren't controlled by engine rpm and can better maintain constant temps. at any speed. I installed an auxillary 12 inch electric fan to help cool the system in stop and go traffic. At highway speeds with a properly maintained system, you don't need any fan; which is why the engine driven fan has a clutch that disengages it at highway speeds.
Bernie
Old Feb 6, 2007 | 10:43 AM
  #47
Durango_Boy
Use MarkVIII fan - $25
CS130 alt - $55
DCC Controller - $125
8 gauge power wire - $5
4000CFM at ALL RPMs - $210
Doesn't sound bad at all.
Old Feb 6, 2007 | 12:27 PM
  #48
Kid Vette's Avatar
Kid Vette
CS130 alt - $55
You forgot to add the two SI alts you burned up and the old controller.
Old Feb 6, 2007 | 12:31 PM
  #49
Durango_Boy
Nah, that was my fault for not researching what those alts were really capable of. One of them was an SI that was upgraded to 135 amp. It burned faster than the stock SI that was already on the car.
Old Feb 6, 2007 | 07:59 PM
  #50
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Ton of money? I got a Mark VIII fan at the boneyard for $11, picked up a good CS144 alternator from a Cadillac at the yard across the street for $15. That's not much at all.
Old Feb 6, 2007 | 08:28 PM
  #51
Kid Vette's Avatar
Kid Vette
Like I said, I just don't understand fixing something that isn't broke. If that's something you want to do, go for it.
Old Feb 6, 2007 | 08:36 PM
  #52
Durango_Boy
Say you're stuck in traffic on a moderately hot day. Just sitting there idling. How high will the temp get? Do you rev the motor to get the temp down while you wait?
Old Feb 6, 2007 | 08:38 PM
  #53
ESU's Avatar
ESU
If you had a running hot problem like some of us do and this mark 8 fan worked and cured your problem you wouldnt think it was a lot of money for little return.
ESU
Old Feb 6, 2007 | 10:05 PM
  #54
turtlevette
If you have that problem then you have a bad fan clutch. An engine driven fan has a lot more capablity than any electric fan. Idle may be the only condition where an electric fan wins.
Its like trying to supercharge you engine with an electric fan, just can't get there playing with 12v.
Wait till those used fans crap the bed when you're in traffic. Probably safer with dual fans if you're going electric.
Old Feb 6, 2007 | 10:17 PM
  #55
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What if it is broke? I had a crappy flex-a-lite fan and spacer in there before...
Old Feb 6, 2007 | 10:19 PM
  #56
Durango_Boy
Don't fan clutches also disengage at high RPM as in high speed highway travel?
Old Feb 6, 2007 | 10:24 PM
  #57
turtlevette
it doesn't disengage but it slips more at higher rpm. The heavy duty clutch is stiffer across the rpm range and it will move some serious air.
The clutch thermostat spring makes it stiffer as temp increases.
I tried the electric fan thing back in the 80's and had electrical problems, thermostat switch problems yada yada yada.
Mechanical fan is simple and trouble free.
To Engine Cooling Perfection Achieved
Old Feb 6, 2007 | 10:57 PM
  #58
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Technology has changed a lot in 20 years...
Old Feb 6, 2007 | 10:59 PM
  #59
Durango_Boy
That's what I was thinking. Better fans...better controllers...and better charging systems. I think it's an even sided concept. Nothing wrong with mechanical fans so long as you can say the same thing for electric.
Old Feb 6, 2007 | 11:05 PM
  #60
turtlevette
Yep,
I give, all the new cars use them so its probably the way to go. My car has never cooled correctly at highway speeds so i'm staying with the mechanical until like you say i put an engine in that doesn't facilitate a mech fan.
