ssb vacuum pump install
Old Jan 27, 2007 | 09:39 AM
nojunk's Avatar
nojunk
4th Gear
Default ssb vacuum pump install
ive got an 81. Has anybody put one of these vacuum pumps in before? Im trying to see the best place to put this pump, not a lot of room under the hood. Does anyone have pics of one installed. the engines got 6 pounds of vacuum at idle. The head lights do not move unless i wake the throttle , no brakes after the 2nd pump, im thinking this pump should take care of all this.
Old Jan 27, 2007 | 09:41 AM
SIXFOOTER's Avatar
SIXFOOTER
So is your vac so low because of cam mods or leaks?
IMHO a Hydroboost is a better way to go, the vac pumps are noisy and I have yet to hear anything good about them. Hydroboost can be done for a couple hundred and will last forever
Old Jan 27, 2007 | 09:46 AM
nojunk's Avatar
nojunk
4th Gear
big cam 256 int 264 exh
Old Jan 27, 2007 | 09:48 AM
nojunk's Avatar
nojunk
4th Gear
ive got the pump here to should have done my research first
To ssb vacuum pump install
