1975 Vacuum Diag
Old Jan 27, 2007 | 10:18 PM
2005bobby69's Avatar
2005bobby69
Default 1975 Vacuum Diag
Hi Guys Does anyone know where the black with pink stripe hose from heater control hooks. I can not find where it goes
someone maybe have a diagram or a link thanks
Old Jan 28, 2007 | 05:16 AM
Rockn-Roll's Avatar
Rockn-Roll
Yeah...here's a diagram from the 1975 Assembly and Installation Manual which is available from Eckler's and most vette shops:
http://Rockn.Shackspace.com/BlowerCo...WithArrows.jpg
Old Jan 28, 2007 | 05:16 PM
2005bobby69
Default I still cannot find a nipple
I sill cannot find anywhere to attach the hose too
I see the diag and follow to the pump along with the other hose I can only find 1 attachment point on the pump and that is what the other color goes too coul I hae to pull the whole heat box set up to access the back of this pump maybe that is where the missing nipple is
I dont know any help would be great
Old Jan 28, 2007 | 06:44 PM
Rockn-Roll's Avatar
Rockn-Roll
Yes...that device has a diaphram with a vacuum fitting on both sides. And, yes...as I recall when I had mine out it is very hard to get to the one behind the diaphram. And, if you don't know what you are looking for then you will need to feel around back there...just follow the TAN striped line to find the diaphram.
Old Jan 28, 2007 | 10:10 PM
carl a's Avatar
carl a
from my 73 assembly manual should be the same for 75--------------------------
Old Jan 28, 2007 | 10:11 PM
carl a's Avatar
carl a
here;s the head lights while im at it----------------------------------------------
Old Feb 18, 2007 | 03:42 PM
Rockn-Roll's Avatar
Rockn-Roll
Gee Carl...real spiffy! Good job! Crayon's actually do come in handy!
But, you missed filling in the TAN line...you shoulda sprung for the 52 set instead of the 16 colors.
To 1975 Vacuum Diag
