153 vs 168 tooth fex plates?
Old Jan 29, 2007 | 06:20 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default 153 vs 168 tooth fex plates?
I understand that each of these flex plates is different in diameter, the 168 tooth being the larger. How do you know which one shoud be used in a given application? I presume that it's related to the tranny and torque converter rather than the engine, but there doesn't seem to be any consistency.
Old Jan 30, 2007 | 01:53 AM
CA-Legal-Vette
Anyone know which one was used when? I need to figure out what's wrong with the starter on the 73 (TH400) and I'd like to verify that it's the right one.
Old Jan 30, 2007 | 03:09 AM
jackson's Avatar
jackson
168T ... assume it's for your L48 ... so specify it's for sbc 350 ... BBC454 & sbc 400 are different.
Old Jan 30, 2007 | 05:05 AM
Fleetwood's Avatar
Fleetwood
Whats wrong with your starter? could be nothing to do with the flex plate. neil.
Old Jan 30, 2007 | 09:35 AM
CA-Legal-Vette
Correct, it's for the L48 350 with a TH400.
Old Jan 30, 2007 | 09:39 AM
CA-Legal-Vette
You're right, it may have nothing to do with the starter.
When you engage the starter, it makes a horrible, metalic clanking and ringing sound. One of the obvios checks was to see if the correct starter and flex plate were used.
Old Jan 30, 2007 | 09:43 AM
redvetracr's Avatar
redvetracr
I believe your starter will determine which flexplate you need..mounting bolts straight across should mate with the 153T....
....redvetracr
Old Jan 30, 2007 | 08:33 PM
jackson's Avatar
jackson
....redvetracr
AFAIK, OE L48 w/ OE TH400 have OE 168T & OE staggered starter bolts.
To 153 vs 168 tooth fex plates?
