Header Hitting Idler Arm
Old Jan 29, 2007 | 07:16 PM
The3's Avatar
The3
Default Header Hitting Idler Arm
Some of you know I just put a ZZ4 in my 74 Corvette. Tonight I put the passenger side header on and after bolting it tight, I see it's hitting the idler arm. These are Headman headers that came off my old 350 motor and they didn't hit before. The idler arm is new so maybe I got the wrong one. I don't have the old one so take a look at the picture and let me know your thoughts.
yeah I know the headers are rusted but I was going to buy some new ones soon. Maybe now is the time. Anyone install a ZZ4 and have the same problem? Did you replace the header? If so give me a part number and I'll order it tonight. Thanks for any feedback.
Last thing, there are no other holes in the idler arm or frame to be mistaken.
Old Jan 29, 2007 | 07:19 PM
WRC7732's Avatar
WRC7732
Mine hit to, ever since I replaced the stock one with the heavy duty idler arm from VB&P. The heavy duty ones are a lot thicker....
Doesn't bother me that much so I just left it....Haven't had any trouble with it as of yet....Knock on wood....
Old Jan 29, 2007 | 07:59 PM
Durango_Boy's Avatar
Durango_Boy
If it bothers you...maybe 'massage' the header tube a little and give yourself a little bit of clearance.
Old Jan 29, 2007 | 08:08 PM
Crunch-o-Matic's Avatar
Crunch-o-Matic
The3 -- I have a zz4 in my 73 vert and I have Jetthot headers. Header order # H2134. FYI -- it has been a year and a half since I ordered so the item number could be different. I am very happy with the headers.
No clearance issues with these headers.
Cheers,
Crunch
Old Jan 29, 2007 | 08:51 PM
The3's Avatar
The3
thanks guys. I think I will dimple these old headers and order the Jethots. See you on the road.
Old Jan 29, 2007 | 08:52 PM
Durango_Boy
Good luck. We want pics of the new header install.
Old Jan 29, 2007 | 09:07 PM
Restorod '79's Avatar
Restorod '79
I had the same issue, VBP heavy-duty idler arm, much thicker, had to "massage the pipe for 3/8" clearance. I put inexpensive Hookers on, not their fault, next set will be better researched.
Old Jan 31, 2007 | 02:35 PM
Durango_Boy
Was this done gently or all caveman?
Old Jan 31, 2007 | 07:42 PM
b71vette's Avatar
b71vette
I would recommend getting the bare headers, tweak them and then send off for Jet Coating. saves you from dimpling the new coating, that's what I did.
Old Jan 31, 2007 | 08:58 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you may be able to center the motor better by loosening up the motor mounts and trans mount .....
Old Jan 31, 2007 | 09:19 PM
The3's Avatar
The3
I dimpled the header and there is now about 1/4" separation. I am going to see if it hits when the engine is running (vibration). If it doesn't then they will come off and be sent for coating.
bobs77vette, good idea. I will try and move it tomorrow to get more clearance.
Old Jan 31, 2007 | 09:35 PM
tellcom2001's Avatar
tellcom2001
i have a problem like that but its my slave cylinder hitting my exhaust. so im going steroids this week.
Old Feb 1, 2007 | 06:05 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I have a ZZ4 with Dynomax Ceramic covered headers and a heavy duty idler arm from NAPA. No clearance problems at all. Dynomax's are not very expensive and they were bent perfectly for the application. Only set of headers I've ever installed that fit right out of the box with absolutely modifications.
You can get them from Summit or Jegs.
Jason
To Header Hitting Idler Arm
