Thermostat Housing Installation
Old Jan 30, 2007 | 12:46 PM
DO2G's Avatar
DO2G
Default Thermostat Housing Installation
Is any type of sealant (RTV) required around the gasket of the thermostat housing? If so, which side of the gasket or both?
Thank you
Old Jan 30, 2007 | 01:02 PM
redvetracr's Avatar
redvetracr
you really shouldn`t need it with a gasket but a little RTV can`t hurt..
...redvetracr
Old Jan 30, 2007 | 01:21 PM
PRNDL's Avatar
PRNDL
If you have the stock housing and use the paper gasket, I believe those paper gaskets come with instructions to coat both sides of the gasket and let it sit for a few minutes to dry before using. I think I used blue.
Old Jan 30, 2007 | 02:40 PM
JoeRags's Avatar
JoeRags
I dont use any and dont have any leaks... my thermo housing has come off plenty of times... I just toss in a new gasket and I'm good to go.
Guess it cant hurt though.
Old Jan 30, 2007 | 10:44 PM
MidShark's Avatar
MidShark
Like it was stated, you really don't have to use any, but if the housing or manifold mating surface is pitted at all, it is a good idea.
Rich
Old Jan 30, 2007 | 10:48 PM
Big2Bird's Avatar
Big2Bird
Thank you
The only gasket that you should not use sealer on is the $10.00 Felpro silcone one. It is made for multiple uses.
Old Jan 31, 2007 | 08:49 AM
Vette Gator's Avatar
Vette Gator
I was taught to put a small bead of black silicone sealer around the gasket, then work it between my thumb and finger to leave a thin coat all the way around both sides. I've used this method on my transmission pan, valve covers, T-stat housing, etc, and never had any leaks.
Old Jan 31, 2007 | 09:10 AM
CJ 77's Avatar
CJ 77
77/350- I used an RTV product but It was not silicon based. Think it was a brown color though. Only used it because the housing surfaces were pitted. Silicon molecules are there forever. Nice today but what about tomorrow? I live near the Harley Davidson plant. Harley BANS any piece of equipment that uses a silicon based product for that reason. The molecules are everywhere forever and their paint wont adhear as well. I thought that was crap until we sold them a piece of equipment and then had to rip it out. That was a number of years ago but I dont think the philisophy has changed.
chuck
To Thermostat Housing Installation
