Accelerator stuck? rpms keep going up help!
Old Jan 30, 2007 | 05:42 PM
mdjice's Avatar
mdjice
Default Accelerator stuck? rpms keep going up help!
I just changed my Accelerator cable (old one snaped) ad now when I turn my car on, the RPms will slowy go up on it s own...I checked that the cable is not pulling on the carb and it s not, it lets the throttle go back all the way any clues what it could be? as I said the acc cable does not pull at all on the carb when the pedal is not pressed but the rpms will go up anyways.
thanks
Old Jan 30, 2007 | 05:53 PM
Durango_Boy's Avatar
Durango_Boy
Did you remove any springs that were attached to the carb's throttle?
Can you get us a close shot of the carb from the driver's side, with the air cleaner taken off?
Old Jan 30, 2007 | 05:56 PM
mdjice's Avatar
mdjice
ok never mind, it works fine I guess it was just my electric choke going crazy
Now Is it normal that the part connected to the carb is loose?
i found out that if it was too tight, the i could not press the gas pedal all the way without having the plastic surrounding the cable pop out. when it s loose it works fine. I double bolted it just in case but is it noral or is going to unscrew completely with vibration?
als I had to bend the cabl quite a bit to make it fit almost if it was too lon (but it wasn t since the replacment was the exact same size as the original)
Old Feb 1, 2007 | 12:45 PM
Durango_Boy
So everything worked out with the accelerator cable? Good work on a job you did yourself.
Old Feb 11, 2007 | 12:26 AM
mdjice's Avatar
mdjice
yeah it's all good. I know it's nothing big for most of you guys but for me it was pretty satisfying to change the cable myself and figure out on my own....and saving $100!!!
thanx
Old Feb 11, 2007 | 10:08 AM
Durango_Boy
thanx
I know if feels good when you finally turn that corner and start doing the work yourself. Honestly the first step is investing in some tools. Nothing expensive. Maybe a complete set of metric and standard sockets and wrenches. Basic hand tools like wire cutters, needle nose pliers, pliers, crescent wrench, adjustable wrench, rags, drain pans...just buy them one at a time until you have some tools. Then doing your own work is fun and easy. Pick the little things that won't keep your car down long.
Old Feb 11, 2007 | 08:06 PM
genuine1980's Avatar
genuine1980
This might have been the fast idle...
To Accelerator stuck? rpms keep going up help!
