Hooker Coated Rusting ??
Old Jan 31, 2007 | 08:04 AM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
Default Hooker Coated Rusting ??
I have hooker cerm. coated headers and side pipes. 4 months old, 3 month since install.
I see rust coming through??
Is this normal?? If so how to clean?, Paint? ???????
Old Jan 31, 2007 | 09:10 AM
rosslato's Avatar
rosslato
if u bought them thru summit i hear thats quite common. if there jet hot coated & bought them thru jet hot then send em back & they'll recoat them free of charge. it sux bigtime either way.
Old Jan 31, 2007 | 09:38 AM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
I was told by one of the header places, that you should never do a cam/engine break in with coated headers. It will get them too hot and cause them to have some rust later. I found this out after I did a break in. Now my big blick headers have just a small anount of rust starting on them. But that is after 2 years of use.
Old Jan 31, 2007 | 09:41 AM
68 NJConv 454's Avatar
68 NJConv 454
I remember a big post about this within the last six months.
Some said it was common...some said they have gone years without rust showing.
Jet-hot is suppose to coat both the inside and outside with the ceramic coating which helps with both heat and prevents rust. Don't know if the summit headers are coated on the inside, not that your brand new headers should have rusted thru already. Also, if they do a shioty job of coating there could be small airbubles/holes that allow the air and moisture to reach the metal. Either way I would call whomever you got them and complain.
If it was Jet-Hot which i hope it wasn't, complain and send them back and tell them they have to do a top notch job this time b/c shipping alone will be pricey and on your dime.
Good luck!
Old Jan 31, 2007 | 09:43 AM
68 NJConv 454
Blackshark....what make/year truck is that in your avatar??? any more pics? please e-mail to doogie1101@hotmail.com if you get a chance. Thats a sweet truck. Sorry for going off subject...
Old Jan 31, 2007 | 10:50 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Here's a set off a '69 BB that saw frequent street use. Hooker factory ceramic coating. This is after 1 year.
Old Jan 31, 2007 | 11:02 AM
SoCalErv's Avatar
SoCalErv
Army
Crap!!!! I thinking of installing headers on my 69 in the near future. Are the Hedmans any better. I do not want a rusting issue!!!!
Old Jan 31, 2007 | 11:06 AM
King Lear's Avatar
King Lear
Veteran
If that picture if after one year you got hosed, I have had mine on for 2 years and am showing a little surface rust right before the collector but I use one of my old army wire tooth brushes for cleaning M-16's to get it. Other then that mine are clean. They have a one year coating warranty from Hooker.
Old Jan 31, 2007 | 01:11 PM
Wrencher's Avatar
Wrencher
Factory header coatings are junk, no matter what they say. Never seen a set that didn't rust, even the chrome ones that were kept clean, and it's pretty much all brands. In my experience (years), only the Stahls had decent paint or other coatings, and you pay for it. No experience with Jet Hot, but I think they gaurantee against that. Good luck.
Hans
Old Jan 31, 2007 | 03:33 PM
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
From what I have see in pics on the forum, the next headers and side pipes I get will be STAINLESS period. Summit just sent me a message, 90 day warranty from them so I am screwed there and they are telling me to contack HOOKER. Contacting them today. Will let you all know.
Old Feb 2, 2007 | 01:47 AM
Tonys96's Avatar
Tonys96
My Hedman Elites still look like new after 1 year.
Old Feb 2, 2007 | 05:06 AM
Bangkok Dean's Avatar
Bangkok Dean
There is no better metal than Stainless steel
Old Feb 2, 2007 | 01:32 PM
77BuffaloVet's Avatar
77BuffaloVet
This was my biggest problem on startup and break-in. The headers were glowing and peeling right away. Something flameable must have gotten stuck between the pipes where they merge and it caught on fire. As if I didn't have enough to worry about keeping an eye on the engine...I was putting out a fire with the car was running...ugh...
The headers already look worse than the ones jughead posted.
Old Feb 2, 2007 | 02:18 PM
Wrencher's Avatar
Wrencher
Default My fix
When I freshened up my BOSS 302, the Hooker super comps I had on it (purchased new) were pretty rusty, at least for California. I put them in the industrial strength washer I have here at work, used those green 3M pads on them after that, wash again, then painted them with Dupli-Color 1200 degree black ceramic rattle-can paint. I've got about 20k/3 years on the engine now and they still look OK, but not perfect. Sure work well, though!
Hans
Old Feb 2, 2007 | 06:01 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Hooker states that breaking in an engine with ceramic coated headers will ruin the coating.
If jughead's are what I can expect then why bother with the factory coatings? I could just buy cheaper, uncoated headers & expect them to rust. At least I wouldn't be disappointed.
Old Feb 2, 2007 | 08:28 PM
croaker's Avatar
croaker
Mine look just like jugheads
Old Feb 3, 2007 | 11:41 AM
C3 4ME's Avatar
C3 4ME
I think the standard warranty on coatings if you have them coated after you buy them is 3 years. My Super Comps are out for coating right now. I can't wait to get them back to see how they will look.
Old Feb 3, 2007 | 12:07 PM
ratflinger's Avatar
ratflinger
I went out to Jet-Hot's site & it seems they have a limited lifetime warranty on their Sterling coating, however I can't seem to locate their definition of 'Limited Lifetime'. Anyone with the Sterling coating - what does the warranty paperwork state?
I am also thinking about the Jet-Hot 2000 coating, higher temp rating & black color might be nice also since my engine compartment will be mainly black & aluminum anyway.
To Hooker Coated Rusting ??
