Speedometer Drive & Driven gear
Old Jan 31, 2007 | 10:41 AM
avner's Avatar
avner
Default Speedometer Drive & Driven gear
I have some questions, maybe someone know and can help me.
I just changethe diff' in my car a 68 327 Hi Pre' manual M21.
The original diff' was 411 and I changed it with 336, now the car run faster with low rpm (-650) but the speed on the speedo' is not correct.
1.Does someone know what Speedometer driven gear I need,
(how many teeth & color).
2.Does someone know if I need also to change the Speedometer drive
gear inside the transmission?
3.Does someone have a chart with the gear color and teeth for each
gear ratio and transmission
Thanks, Avner
Old Jan 31, 2007 | 12:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
One of the aftermarket providers (ZIP, Eckler's, CC -- can't remember which) has a chart in their catalogue. You should be able to match your ratio to the correct color drive and driven gears.
Old Jan 31, 2007 | 07:33 PM
Duke94's Avatar
Duke94
Thanks, Avner
Boy, this is the week for speedo gear questions. Just posted the chart in another thread, Here it is. Looks like it uses the same drive gear.
Old Jan 31, 2007 | 08:04 PM
Bob3700's Avatar
Bob3700
Default Thanks
Duke,
Thanks for posting the 4 spd info. As it turns out, I think I have the correct gear in stock, just need to install it.
Bob
Old Feb 1, 2007 | 04:36 PM
avner's Avatar
avner
To Speedometer Drive & Driven gear
