Diff Problems!!
In two years this problem seems to have got worse (initially, these symptoms would only persist when car was hot) but new diff oil and additive seemed to cure the problem.
While the car had a full suspension overhaul last month, the garage has not experienced ANY of the noises that I describe in the time they had the car!
After I had picked her up from the garage, I can't have got further than 10 miles down the road before the problem reared its ugly head once again. I did a U-turn and headed back to the garage. With all the mechanics watching, I slowly inched her backwards and forwards - with an ALMIGHTY creaking noise coming from somewhere underneath. It sounded like the the rear wheels had seized up or something!!
The problem is that once they got her back on their ramp, they couldn't find anything wrong with her. I left her there and they have been driving her for the past week - trying (unsuccessfully) to bring the symptoms back. These guys are Corvette specialists but they say they can't be 100% sure if it is the diff.
The last piece of information that might be worth mentioning is that the diff oil has been changed twice in the last two years and each time the old oil has literally been BLACK.
I am lothe to replace my diff unneccesarily but don't think I have a choice. Can anyone confirm that these symptoms sound like diff problems or perhaps there is something else I am overlooking.....???
You can check the yoke play, U joints, and rubber bushings with the car in the air, but if they check out you may have to drop the differential and open it up. If you get to this point and need help let me know and I'll go over it with you. Hopefullly you find something other then the diff but it does sound like the posi.
So if they replace my diff (and while they're under there check the U-joint, etc) the problem should be resolved you think?
In your experience, can wheel bearings cause these sort of symptoms?
Problem only occurs when driving slowly and earlier only when driving slowlay after having drivin for a while. Now it too seams to happen after shoter periods of time...
Just when I had those Vortec heads saved up...
baffles me why the symptoms aren't continuous...
Here is the type of clutch you have in yours, it isn't supposed to be in several pieces. I know vendors are still using these and well as the fiber clutches.
Here is a brand new never used fiber clutch. Notice the flat spots on it where I rubbed my finger against it very lightly.
This is what your posi looks like with the springs in it. This is a new Eaton with the large springs,fiber clutches, and less clutch plates. Commonly used in exchanges, use 2 bottles of additive with these for sure.
i must admit that i'm not much of a mechanic myself, but i'm still learning..
If I get the diff replaced should this sort all these problems we're discussing, or are any of the components you mention separate from it?
forgive my ignorance.
