Engine Swap
Old Feb 1, 2007 | 12:45 PM
VETTEROOKIE75's Avatar
VETTEROOKIE75
Default Engine Swap
Has anyone put a late model Vette engine into a C3 Vette?
Old Feb 1, 2007 | 01:13 PM
Durango_Boy's Avatar
Durango_Boy
When you say late model, which do you mean. There were several motor changes since the C3, and even one during it's tenure.
Old Feb 1, 2007 | 01:20 PM
VETTEROOKIE75
Late models I'm talking about is like from late C4 and C5.
Old Feb 1, 2007 | 01:24 PM
Durango_Boy
Well C4s had the LT1 engines, which were a roller version of a Gen1, and with the exception of the accessories...depending on where you got it...they fit right in. There were some minor things to change...but it's a bolt in.
Then there was the LS1. It has cousins, LS2, LS7, and now the $25K LSX. The LS motors will fit...but it costs a lot of money and it's not a simple drop in.
I would suggest you narrow it down to what you want to put in, and go from there.
Old Feb 1, 2007 | 02:25 PM
Xakk's Avatar
Xakk
That depends on what year C4 you're talking about. Early C4 L98s were standard 350 Gen I roller blocks. LT1/LT4 from 93 up are Gen II block.
Old Feb 1, 2007 | 02:28 PM
Durango_Boy
Right, and that's hat I meant about the engine change at the end of the C3s.
Old Feb 1, 2007 | 07:50 PM
markdtn's Avatar
markdtn
I have an L98 TPI from a 91. Several have LSx engines. I'm sure there are a bunch with LT1s as well. Do a search on my username and TPI and you will find my install suggestions on a TPI. LT1 is similar, but you have to use LT1 accessories. LSx is vaguely similar, but you have to do more mods. That said, if I was doing it today, I would do an LS engine.
Old Feb 2, 2007 | 11:04 PM
martinsw's Avatar
martinsw
I am in final stages of putting a 2000 C5 LS1 engine into my 79 vette. Also using a camaro T56 tranny. Lots of folks have done this conversion - as others said, search and you will find some. LS1tech.com is a great source if you do this. You can also do LS2 or LS7 - but more used LS1's available for lower costs....
Old Feb 3, 2007 | 03:16 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Default LS7 in a C2
Check out this!http://youtube.com/watch?v=52Una0HD9...elated&search= And this!http://www.youtube.com/watch?v=FmC03fITfjA And this!http://www.youtube.com/watch?v=vQA3m4ZdO0k
To Engine Swap
