Fuel return & vent line?
Old Oct 8, 2001 | 11:36 PM
Jack71's Avatar
Jack71
Default Re: Fuel return & vent line? (Mike69)
Just a little forum exaggeration in my first message -- it would take quite a fuel pump to implode a tank. Although, somebody on this forum has probably done it.
Nifty mount for that regulator Red73, where did you acquire that? I couldn't find anything even similiar in the Summit catalog. That is a clean setup.
[Modified by 74jack, 3:38 AM 10/9/2001]
Old Oct 8, 2001 | 11:54 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Fuel return & vent line? (74jack)
Thanks Jack.... but I gotta say you scared the poopie out of me!!! :lol: :rolleyes: :lol:
Old Oct 9, 2001 | 04:52 PM
Paul 75 L82's Avatar
Paul 75 L82
The best way to have a fuel return line and an aftermarket fuel pump is to install a fuel filter that has the return outlet on the body of the fuel filter. At one time someone posted a pic of one they were using, I went to the auto parts store and saw many that had the return line from the filter. Good Luck.
Old Oct 9, 2001 | 05:12 PM
BeaterShark's Avatar
BeaterShark
Default Re: Fuel return & vent line? (Paul 75 L82)
AlwaysWave,
please send me the pic.
Red73,
What do you use for the restriction off of the regulator? I have the Holley 803 and the two out ports are considered equal (ie. either could be used to feed the carb). So, how do you restrict the return line to keep decent fuel pressure to the carb?
Old Oct 10, 2001 | 01:33 AM
marky mark's Avatar
marky mark
Paul has the right answer.
You run the fuel return line off the fuel filter, A/C 432 which is a good size inline filter. Zip and Dr. Rebuild sell the fuel line kits to fit your application. They are exact replicas of originals. I can't imagine why you would plug the fuel /vapor return line. It serves a purpose by allowing unneeded fuel to go back to the tank instead of being pushed into the carb.
I've read that the hi-per big blocks running holley carbs in the late 60's had piston ring damage due to fuel seepage into intake when car had been turned off (no where for fuel under pressure to go).
Just a thought.
regards, mark :chevy
