Factory Timing Gear Orientation
Old Feb 4, 2007 | 02:58 PM
dinodon51's Avatar
dinodon51
Default Factory Timing Gear Orientation
This ia a rookie question, but I seem to have confliciting direction when I look at several tech manuals. I am changing cams in my small block and the factory timing gear has an arrow. Should I have the arrow oriented at 1200 high or 6 oclock low as I put the timing chain on? When I put the timing cover back on should I have the top arrow at 1200 or 0600 for when I drop my distributor back in?
Thanks...I am at "all stop" until I resolve this.
DFS
Old Feb 4, 2007 | 03:45 PM
proz78silv's Avatar
proz78silv
7th Gear
Crank Timing mark at 12:00 with #1 at TDC.
Cam timing mark at 6:00.
Old Feb 4, 2007 | 04:08 PM
Ironcross's Avatar
Ironcross
A point of interest. Just be aware that with the cam at 6 and the crank at 12 setup, the engine is firing at #6, not #1.
Old Feb 4, 2007 | 07:35 PM
proz78silv's Avatar
proz78silv
7th Gear
You better go read your info again.
http://www.compcams.com/Technical/In.../Files/172.pdf Page 2
Old Feb 4, 2007 | 10:05 PM
stingr69's Avatar
stingr69
Both #1 and #6 will be at TDC but only #6 is ready to fire. If you have the crank dot at 12:00 and the cam dot at 6:00 when you assemble the pieces, you want the disrtibutor to be pointing at the #6 spark plug wire tower when you drop it in. That is the confusing part.
-Mark.
Old Feb 4, 2007 | 10:12 PM
Big2Bird's Avatar
Big2Bird
-Mark.
Yep
Old Feb 5, 2007 | 06:31 PM
Duke94's Avatar
Duke94
Does this help? #1 is at TDC.
Old Feb 5, 2007 | 06:41 PM
TimAT's Avatar
TimAT
Yep, but it's ready to fire #6. Top of #6 compression stroke.
Old Feb 5, 2007 | 06:53 PM
Ironcross's Avatar
Ironcross
Who was this statement directed or addressed too?
Old Feb 5, 2007 | 08:07 PM
77BuffaloVet's Avatar
77BuffaloVet
put it in that way with the marks at 6 and 12 and then turn the engine 180 and put the distributor in to fire # 1 or leave it as it is and put the distributor in to fire #6...
Old Feb 5, 2007 | 08:12 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Untill heads / manifold are on who puts in the dist?
Old Feb 5, 2007 | 08:23 PM
C3 Stroker's Avatar
C3 Stroker
What often happens, though, is that people turn the engine after installing the heads and intake to feel for the compression stroke on #1 plug, then drop in the distributor (not being able to see the change in timing mark orientation).
Old Feb 5, 2007 | 08:32 PM
77BuffaloVet
ha ha cute...I don't know...you? Oh yeah...make sure you put the heads and the manifold back on...don't forget the carb...
Old Feb 5, 2007 | 09:08 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I guess I could cut a hole in the manifold to slide under the dist?
That way all the crank turning will prime the oil pump while I
set the valves, turn the pushrods and set the lash.
That way I wouldnot loose TDC #1 firing Position.
It is a sneaky position.....................
Thats for the advice
Old Feb 5, 2007 | 10:25 PM
mandm1200's Avatar
mandm1200
The original thread only mentioned a cam change. The heads do not have to come off for that.
I wouldn't worry about dropping in the distributor until after the valve lash is set. Some may want to drop in the distributor after installing the lifters, pushrods, and intake mainfold; prior to any rotation of the crank/cam.
Old Feb 5, 2007 | 10:47 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
OK I agree
Manifold must come off to change cam.
Pictures show no heads.
I read the whole thread and see it side tracked to
#6 cyl vs #1 cyl
and talking about putting it in.....................
untill the manifold is on there is no place to put it.
Sooo I ask this , who puts dist in before manifold?
Old Feb 5, 2007 | 11:06 PM
TimAT's Avatar
TimAT
DFS
OK-- I'm tired.
Put everything back together and then---
Just before you drop the distributor in, remove the #1 plug. Stick your finger over the plug hole and crank the engine until it blows your finger off. Look at the timing mark on the balancer, then rotate the engine until the marks for "0" line up. Turn your distributor to point at the #1 plug wire tower, and drop it in. The oil pump shaft will probably NOT line up, so hold the distributor with a little bit of downward presssure and crank it over some more. The disty will drop right in. Now put your finger back in the #1 plug hole, crank it over until it blows your finger off, verify the rotor points at the #1 tower on the cap and the timing marks are close. Sounds like a lot. It's not and it works EVERYTIME!!!
To Factory Timing Gear Orientation
Old Feb 5, 2007 | 11:32 PM
dinodon51's Avatar
dinodon51
Thanks to all. Looks like the last post is doable.
But I wonder why you cant move the engine to #1 full compression, slide in the distributor, mount heads (less rocker arms) and intake manifold. Then put the rocker arms on and adjust them.
Old Feb 5, 2007 | 11:42 PM
TimAT's Avatar
TimAT
When you adjust the valves, you're going to turn the engine over. No way around it. The procedure for adjusting hydraulic lifters is in every manual I've ever seen. And it's easy to follow. Just hang back on the disty- do it last.
Install the heads, intake, valve train, you can even install the carb. And if you want, you can install the disty. It'll work that way too. But you're still gonna' turn the engine to adjust the valves.
Old Feb 6, 2007 | 01:58 PM
Ironcross's Avatar
Ironcross
I have sold tons of timing sets and the number one question when a novis is doing the job and the engine will not start with the dots lined up. The simple explaination is that the engine was at 6 and not 1. Very obvious that not everybody knows this from my experience of selling timing sets. And so too on this forum from the questions asked.
