BB Valve Cover Leaks
Old Feb 5, 2007 | 02:01 PM
69/03vette's Avatar
69/03vette
Default BB Valve Cover Leaks
My 69 427 original valve covers leak. Thought Felpro was the way to go. Is there anything better or do I just RTV silicone the ones I got?
Old Feb 5, 2007 | 02:25 PM
TimAT's Avatar
TimAT
Are they flat? Make sure the sealing edges are flat and square. Not bent where someone overtorqued the bolts. I also use the factory reinforcements on all the bolts. And then are you using factory heads? or aftermarket? I saw a post not too long ago someone had aftermarket heads and they had cut halfway thru the gasket surface to clear someting in the head? I use El-Cheapo rocker gaskets on my BB because I get to adjust valves, and never had a problem with them leaking..
Old Feb 5, 2007 | 03:25 PM
Bob3700's Avatar
Bob3700
Default Corvair valve Cover Tie Downs
This goes back a long way but in keeping with what TimAT said. Using the reinforcements under the bolts is a good thing.
Years ago, we used (and I still do) the Corvair valve cover reinforcement/tiedowns. They are a lot beefier and longer than the stock BB units (probably 3/16 inch thick). They apply more downward pressure to those pesky low side valve cover gaskets.
Are you using cork or the fel-pro rubber?
Bob
Old Feb 5, 2007 | 07:37 PM
SmokinBBC's Avatar
SmokinBBC
Bob
Where do you get the Corvair valve cover replacements/tiedown?
Old Feb 5, 2007 | 08:25 PM
Bob3700's Avatar
Bob3700
Default Springs?
Wow, I was sort of afraid that you would ask that question.
Wonder if any of the repo people dealing with Corvairs would have them?
They are tricker than S&&t if you can find them.
Dude, can't believe that I still had a couple in the original boxes sitting in my tool box. The GM part number on that box is:
#3850874 and they are called springs (don't ask me why cause they don't look anything like a spring)
See if that number is still good or can be crossed by the Corvair repo people.
They are worth the trouble to find.
HTH
Bob
Old Feb 6, 2007 | 12:34 PM
77-L48's Avatar
77-L48
Default Fixing Valve Cover leak
All of this sounds good. I usually clean off the old gasket make sure the top of the head and bottom of the valve cover are dry. (Carefully clean them with acetone or brake kleen) Take a small pien hammer to the inside valve cover bolt holes to make sure they are flat or very slightly bent up. Use 3M weatherstipping glue to glue the gasket to the valve cover. Let that cure for a little bit then put RTV (or Room Temperature Vulcanizing) on the block side of the gasket and let that cure for 10 to 15 minutes. Put the valve covers on and torque to spec. Let that dry for an hour or so before you start it. Also, make sure your PCV vacuum is working correctly. If you do not have enough PCV vacuum, the pressure will aid in the valve cover leak.
Good luck.
Old Feb 6, 2007 | 12:56 PM
69/03vette's Avatar
69/03vette
Default Also, make sure your PCV vacuum is working correctly. If you do not have enough PCV v
Since I just got this back togrther I don't have any PCV stuff connected yet. I would'nt have thought this would make a difference with the valve covers leaking
Old Feb 6, 2007 | 01:35 PM
Wrencher's Avatar
Wrencher
Default These guys have 'em...
Clark's Corvair on the east coast, or Corvair Underground on the west. Also, Larry's Corvairs in L.A.
Kragen/Shuck's/Checker has 'em in chrome as well, at least the Kragen in my town. I use 'em on my SB 327 race engine in the T/A.
Old Feb 6, 2007 | 02:04 PM
77-L48's Avatar
77-L48
Default I would'nt have thought this would make a difference with the valve covers leaking
Slight pressure builds up inside the crankcase without PCV and that pressure will find a way out. With a vent in the Positive Crankcase Ventilation hole and weak gaskets, it can aid in the gaskets leaking.
Old Feb 6, 2007 | 02:14 PM
Hvymtlc5's Avatar
Hvymtlc5
You try using those big thick (approx 5/16) metal center gaskets - be made by Fel Pro? Got them on mine and not so much as a drop. They have been off 10 or 15 times and still won't leak. Cost like 40.00 but worth it. No sealer needed. FPP-1635.
To BB Valve Cover Leaks
