Cruise Control Wiring Harness
Old Feb 5, 2007 | 07:50 PM
PhotoVette1's Avatar
PhotoVette1
Default Cruise Control Wiring Harness
Anybody know why the cruise control wiring harness has about 30 feet of extra wire taped up inside of it?
I was going to just run a couple of wires out to the tranducer, but I saw that bundle of wires and got suspicious that it has a purpose.
So I ordered and installed a replacement harness. Which also had the same lump of wires in it.
Why? Just curious.
Old Feb 5, 2007 | 08:12 PM
Binnie77's Avatar
Binnie77
It is possible that it was cheaper for GM to make the harness to fit multiple vehicles. If the only difference was the length in wire, then all they did was leave the extra length inside the loom on vehicles that didn't require that length. That is my theory and I am sticking to it :-)
Old Feb 5, 2007 | 11:10 PM
SIXFOOTER's Avatar
SIXFOOTER
thats kinda weird, mine was a short pigtail, but someone had operated on it and left off the ground, I think thats wht it wasn't working
Old Feb 6, 2007 | 06:49 AM
theoUK's Avatar
theoUK
I think you're describing the resistance wire, designed to hold the cruise transducer solenoid in with a small current, after it's been engaged with a larger current from the main power feed wire.
If you look at the transducer there are two plugs - "hold" and "engage". You'll probably find the hold terminal connects to the unusually long wire.
Old Feb 6, 2007 | 10:43 AM
Duke94's Avatar
Duke94
Why? Just curious.
The wiring diagram I have for my 78' shows a Brown resistance wire that looks like it's the one. It functions as explained by theoUK
Old Feb 6, 2007 | 11:35 AM
theoUK's Avatar
theoUK
Duke,
That's the fella
Colours are a little different on my 80 (green and blue) but it's basically the same setup.
Theo
To Cruise Control Wiring Harness
