Temperature sender help (different sizes?)
Old Feb 6, 2007 | 08:12 PM
69 Vette's Avatar
69 Vette
Default Temperature sender help (different sizes?)
Im putting a Ram Jet 350 into my 69 and just found out that the original temp sender wont fit into the head on the Ram Jet. As you can see in the pic the plug that came out of the Ram Jet head is much smaller. Does anyone make a smaller temp sender with the single pole wire hookup? If not, what do i need to do to get my temp gauge working?
Old Feb 6, 2007 | 08:32 PM
Durango_Boy's Avatar
Durango_Boy
Get one off a newer model I think. Maybe I'm wrong but I do remember them getting smaller I just can't remember when.
Old Feb 6, 2007 | 08:49 PM
rcread's Avatar
rcread
You can either drill and tap the head for the larger sensor (I went this route) or you can go to the hardware store and find an adapter (or two) with the appropriate threads.
Old Feb 6, 2007 | 08:53 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Here's a recent thread that will be some help
http://forums.corvetteforum.com/show....php?t=1602730
Old Feb 6, 2007 | 11:12 PM
Durango_Boy
Did the senders get smaller at a certain year though? This comes up a lot.
Old Feb 7, 2007 | 12:04 AM
BSiegPaint's Avatar
BSiegPaint
'78? '79? It was a specific year, but I'm at a loss to tell you which one exactly. I know when I asked for the smaller sender for my '71, I just ordered one for an '82. Then I Dremel'd the blade connector to fit in my pin connector housing and it works fine!
Did a little more checking - 1979 was the first year of the smaller threads, and the sender should be the same through '88.
Old Feb 7, 2007 | 10:36 AM
Durango_Boy
That's what I was thinking was the case.
Old Feb 7, 2007 | 06:17 PM
qwik-tripp's Avatar
qwik-tripp
Borg Warner WT 510 works great.
Old Feb 7, 2007 | 06:59 PM
marshrat99's Avatar
marshrat99
I'm not sure about the 79. I build a new engine with Dart heads about 3 years ago and the original senders for my 79 L82 were the larger size and had to fab adapters from the local hardware.
Old Feb 7, 2007 | 10:53 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
1979 was the first year for the change from a 1/2" NPT to 3/8" NPT..
To Temperature sender help (different sizes?)
