Cruise Control Problems HELP!
Old Feb 7, 2007 | 03:23 AM
Robert Potter's Avatar
Robert Potter
Default Cruise Control Problems HELP!
My 1982 has cruise control. When I set it, it wants to immediately increase by 3-4 MPH. Then, as if it notices the problem, it will decrease throttle and drop 5-6 MPH. If I place my foot on the gas pedal, I can sometimes coax it into behaving. Then, when a slight hill comes my way, it starts all over again.
I have checked the cable from the cruise control unit to the throttle bodies, it is smooth. The cable to the unit from the transmission is smooth. I don’t believe there are any vacuum leaks either.
I have had this car for 17+ years, and it has always done this. IT DRIVES ME NUTS!!
Robert
Old Feb 7, 2007 | 04:19 PM
Glassbowtie77's Avatar
Glassbowtie77
Servo?
Old Feb 7, 2007 | 05:06 PM
jyounane's Avatar
jyounane
Default Excellent info here!!!
See this paper by Theo in the UK....
http://www.nottingham.ac.uk/~eaztl1/...trol_recon.htm
I found it to be excellent!!!
Joe
Old Feb 7, 2007 | 08:04 PM
Sean82's Avatar
Sean82
the above link is the best place to start.
The next best thing is to ensure none of your vacuum lines are leaking.
To Cruise Control Problems HELP!
