Cruise Control Problems HELP!
Old Feb 7, 2007 | 03:26 AM
Robert Potter's Avatar
Robert Potter
Default Cruise Control Problems HELP!
My 1982 has cruise control. When I set it, it wants to immediately increase by 3-4 MPH. Then, as if it notices the problem, it will decrease throttle and drop 5-6 MPH. If I place my foot on the gas pedal, I can sometimes coax it into behaving. Then, when a slight hill comes my way, it starts all over again.
I have checked the cable from the cruise control unit to the throttle bodies, it is smooth. The cable to the unit from the transmission is smooth. I don’t believe there are any vacuum leaks either.
I have had this car for 17+ years, and it has always done this. IT DRIVES ME NUTS!!
Robert
Old Feb 7, 2007 | 08:11 AM
PhotoVette1's Avatar
PhotoVette1
Robert
You should just buy a rebuilt modulator--evidently the original is defective--I just did and it locks onto the speed perfectly--they're fairly cheap and easy to replace.
Old Feb 7, 2007 | 09:45 AM
theoUK's Avatar
theoUK
Before buying a new transducer, I'd strongly suggest trying to clean and adjust your present one. I put some info together on this a while back,
here
and here
Cheers
Theo
Old Feb 8, 2007 | 11:31 PM
Robert Potter
Default Cruise Control Problem, Thank you!
Thank you everyone for your input on my cruise control issues!
Robert
Old Feb 8, 2007 | 11:52 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Check the vacuum hoses................
They will close off with a tight bend.
I had similiar problems, a piece of metal tube
bent placed int the line eliminated the block.
To Cruise Control Problems HELP!
