Windshield wipers
Old Feb 8, 2007 | 01:24 AM
jhuff's Avatar
jhuff
Default Windshield wipers
Mine only work when they want to. This hardly ever coincides with when I actually need them to. I replaced the switch inside, but thats about it. Before I replaced the switch they didnt work at all. Any ideas?
Old Feb 8, 2007 | 07:33 AM
Disco_Mike's Avatar
Disco_Mike
this post might help
http://forums.corvetteforum.com/show...ighlight=wiper
Old Feb 8, 2007 | 02:16 PM
jhuff's Avatar
jhuff
Originally Posted by GotNoMojo
that thread was mainly for 80-82 wipers. Some stuff was useful, but I have a 75.
Old Feb 8, 2007 | 03:05 PM
75coupered's Avatar
75coupered
Make sure that you have a good ground to the switch, it grounds through the carrier (gauge console) but this is not the best so I would suggest running a seperate ground wire from the switch body to a known good grounding point.
Also make sure that the switch is plugged in correctly, it is easy to plug it in upside down causing a host of odd operation issues.
Good luck
Old Feb 8, 2007 | 04:02 PM
red7d7's Avatar
red7d7
Good luck
I agree, Once I re-did the ground on mine I have not had any more problems with them.
Old Feb 9, 2007 | 04:07 PM
justanotherdoe's Avatar
justanotherdoe
Check ALL of the grounds - I've had intermittants both at the motor and at the switch inside.
To Windshield wipers
