Align specs on lowered suspension
Old Feb 8, 2007 | 03:41 AM
acmsal42's Avatar
acmsal42
Default Align specs on lowered suspension
Much to my regret I took my C3 to a local alignment shop that was recommended to me after I lowered (cut a coil on each F41 spring, 8" spring bolts on rear)the car and installed 17" rims. The car tracked perfect with the stock setup, but this shop is telling me it's difficult to get the alignment within spec. with my changes. Can anyone tell me if dropping the car and widening the track would radically alter the ability to get the car within spec?
A. Sclafani
Old Feb 8, 2007 | 06:16 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
What exactly is out of spec, and what kind of equipment was the shop using?
Old Feb 8, 2007 | 08:11 AM
acmsal42's Avatar
acmsal42
i.e. pass rear can't get toe close enough to -1/32. I think a Hunter?
Old Feb 8, 2007 | 12:16 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I would have expected rear camber problems with the lowered suspension. If the problem is with the shims at the front of the trailing arm, you might have a T/A that's bent out of spec.
Old Feb 8, 2007 | 01:53 PM
zaphodbebullbrox's Avatar
zaphodbebullbrox
Default no problems here
my shark has been lowered and there was no issue with getting it aligned.
it may be something else on your car is outta wack. something bent maybe?
then again it maybe the shop?
Old Feb 8, 2007 | 10:20 PM
acmsal42's Avatar
acmsal42
actually as it turns out all the numbers fall into spec between van steel's published advance street and autocross alignment specs, except the rear camber is a tad more neg than I'd like it, by 1/2 degree. My issue with the car is that it stills pulls to the right just a bit. But I'm using a set of slightly used Sumitomos on 17 X 9" rims. I'm going to install my stock BFG's and see if it tracks straight.
the numbers
front left front right
-0.6 camber =0.8
2.6 caster 3.2
.01 toe .01
rear left rear right
-0.9 camber -1.0
.18 toe .24
Old Feb 9, 2007 | 08:03 PM
76stingracer's Avatar
76stingracer
Equal numbers side to side is the key.
Get the front caster closer to equal and make the rear tow less and equal on both sides. If everything else is in working order, ie straight frame, suspensions parts then the car should track.
Old Feb 11, 2007 | 03:00 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Fix that unequal mess up front.
To Align specs on lowered suspension
