Educate me on electric external fuel pumps...
Old Feb 8, 2007 | 07:46 PM
Secret Squirrel's Avatar
Secret Squirrel
Not 'gonna really help your cause sorry, why are you going electric?
I only ask because i've just switched from a BG 400 back to mechanical....no wiring,less fuel lines,so less chance of a leak.......and the big bonus, I can now hear my supercharger over my fuel pump
My POV only, if your mechanicals working, why not stick with it?
cheers
Jim
Old Feb 8, 2007 | 08:55 PM
Ironcross's Avatar
Ironcross
Originally Posted by Twin_Turbo
unsightly? pretty!!
as for pumps, I would suggest you get a high quality pump like aeromotive or sx brand or maybe those new black anodized holley badged aeromotive pumps. A quality pump will last a lifetime, supply all the fuel you need, higher press. up to regulator & regulator assy eliminate vapor lock.....there are many benefits, the only drawback is cost.
WTF
Old Feb 8, 2007 | 11:12 PM
Solid LT1's Avatar
Solid LT1
I run a Carter "NASCAR" spec mechanical fuel pump on my Vette motors, why? because they give a variable fule curve and work well at all voltages. If I were to go to a EFI set-up that would be another story but, because they help assist the fuel curve and have perfect charateristics for a Holley 4bbl, I will continue to fun maechanical pumps on my Vettes.
Old Feb 9, 2007 | 01:59 AM
DREGSZ's Avatar
DREGSZ
Hey Mike,
Put it on the Dyno and watch the fuel pressure on your meter.
That will tell the whole story.
I can tell you on <--- Big red, we had almost 600 hp and dropped to 4lbs of fuel pressure on the dyno pulls.
We couldn't get enough volume of fuel through the stock lines with the holley blue and regulater combo. to feed the 415 stroker, solid roller. Demon 850
We ended up going to a MagnaFlow pump, (I highly reccommend after doing alot of research)
and pulling the stock fuel lines off the frame and running -8AN lines instead,and making a custom tank pickup.
this will educate you a bit:
http://www.magnumforce.com/store/det...&Search=&Page=
Big motors take big mods and big money
Have fun...
Old Feb 9, 2007 | 02:19 AM
mrvette's Avatar
mrvette
mounting a pump close to the tank is real easy, all you have to do is bend a small bracket:
Marc, DAMN, you are good, man....wish I could afford to pay you to work on MY car.....I just set back and watch....trouble is...I tend to BS too much so little would get done....
