Another 18 x 8 Rim Question...
Old Feb 8, 2007 | 08:04 PM
rjken1969's Avatar
rjken1969
Default Another 18 x 8 Rim Question...
Anyone run 18" x 8" set up all the way around? I'm looking at a P255/50 or 45 tire on that rim size. Will this set up rub?
Pics would be great.
Thanks.
Rob
Old Feb 8, 2007 | 10:23 PM
75 Hot One's Avatar
75 Hot One
You may have to trim the Front lower wheel wells similar to the'78-82's. I'm running P255's on 18X9" wheels on a '75 & had to trim the wheel wells. A belt sander works well.
Old Feb 8, 2007 | 10:43 PM
rjken1969's Avatar
rjken1969
I currently have P255/60/15s with no rubbing. I 'm trying to keep a similar wheel diameter. I'm just nervous about the 18s on front. I see most people run 17s on front and 18s on rear.
Old Feb 9, 2007 | 01:42 AM
Graemeinvette's Avatar
Graemeinvette
I have 18"x8" on the front (18"x9.5" rear) with 245/40/18's and have no clearance issues.
Old Feb 9, 2007 | 03:08 AM
zaphodbebullbrox's Avatar
zaphodbebullbrox
i'm running 18 X 8.5 all around with 255/45 tires, no issues even with shark being lowered.
Old Feb 9, 2007 | 08:33 AM
rjken1969's Avatar
rjken1969
Your car looks great. Where did you find the 18" Rally wheels? The 9.5" fit on the rear without modfication? What size tire are you running on the rear?
Sorry for all the questions.
Old Feb 9, 2007 | 08:49 AM
shafrs3's Avatar
shafrs3
Remember that just because your increasing wheel diameter, the overall wheel tire combo doesn't change the overall diameter because of the lower profile of the tire. The 18" combination is still about 26" in diameter as was the original F70-15 tire.
Old Feb 9, 2007 | 09:23 AM
C3Paul's Avatar
C3Paul
18"x8" with 255/45 tyre will have the same rolling radius as 15"x8" with 255/60 tyre.
Old Feb 9, 2007 | 10:53 AM
blackscreek's Avatar
blackscreek
Paul,
What back spacing are your 18x8 wheels? Could you post a picture of your car with those wheels.
Old Feb 9, 2007 | 04:04 PM
C3Paul's Avatar
C3Paul
Originally Posted by blackscreek
Paul,
The wheels are The classic American Racing TT2,18"x8" with 4" backspace.
As a new member with basic status, I can not post attachments.
Old Feb 12, 2007 | 03:03 PM
Graemeinvette
Sorry for the delay in coming back, Ive been travelling!
Thanks for your kind words about my car, the wheels are alloy 18" replicas of std. Rallye's and are made by The Newstalgia wheel Co, here's there website http://www.newstalgiawheel.com
For the rear wheels the only thing I had to do was re-locate the parking brake cable to the top of the trailing arm, a fairly std. mod.
You can see more of my car on my web site at www.GraemeInglis.com
Cheers
Graeme
Old Feb 12, 2007 | 03:29 PM
steve dalla's Avatar
steve dalla
i have 18-8's all the way around 255-45-18 bolt right up no rubs
Old Feb 12, 2007 | 04:34 PM
69autoXr's Avatar
69autoXr
I'm looking at a P255/50....
A 255/50 on an 18 would be very tall (28 inches) and would very likely rub. Stay away from that size.
Old Feb 12, 2007 | 07:32 PM
36chambers's Avatar
36chambers
Default i can help
http://www.cardomain.com/ride/2395064 check this link for pictures.i went with 245 45 18 f1 gs d3 tires from tire rack and 18 8.5 front and rear rims. it was straight bolt.
To Another 18 x 8 Rim Question...
