H pipe results
Old Feb 8, 2007 | 11:10 PM
okinawa86vette's Avatar
okinawa86vette
Default H pipe results
I had to get a few welds re-done that were a little shoddy on the exhaust and while I had it in, I talked to the owner of the shop (with a really nice 78, mildly built motor) about X and H pipes. He mentioned that an X pipe looks cool but on lower hp vehicles isn't really helpful. It's more for very high RPM, high hp motors.
Anyhow, mine's a small block, probably around 350-375hp or so....041 heads and a pretty healthy cam. The exhaust looks like one of those systems you'd get out of mid america or something.
I got the H pipe in and the sound is way, way quieter. I almost can't believe 8 inches of pipe could do that. It does sound less like a big cam race car and more toned down like a muscle car should. Much less rowdy, which I'm ok with. But it's a little too quiet for me.
What i really noticed, though, is the low end torque. Before, with the cam I had, it really didn't come alive till after 2000rpm. Now, it spins up quicker and gets into its power band faster. It jumps off the line. Of course, this is all butt-o-meter, so it may not have made much difference on paper. I'm really happy with it for anyone that was contemplating it.
C
Old Feb 8, 2007 | 11:28 PM
MN80Vette's Avatar
MN80Vette
I put an H-pipe on my '80 with full length ceramic Dynomax headers on a GMPP crate this summer. I like the even sound. I noticed a big difference on my butt-o-meter too!!
Old Feb 8, 2007 | 11:30 PM
another-user's Avatar
another-user
ive gotta put all new pipes and mufflers on mine this spring. i may see about adding in something like this. can always use more low end torque.
Old Feb 9, 2007 | 02:43 AM
RIJVETTES's Avatar
RIJVETTES
sometimes ya gotta trust the ol butt-o-meter, especially if ya really know your car.
Old Feb 9, 2007 | 07:40 AM
blctalon's Avatar
blctalon
Do you have to buy the H pipe from somewhere or can the shops usually just make it out of regular pipe? I'm still waiting to put exhaust on my 78 406ci. I ordered the super 40s from jegs wednesday and hope to be in the exhaust shop next week/weekend.
Old Feb 9, 2007 | 07:49 AM
Gordonm's Avatar
Gordonm
The shops can make one up very easily. I had mine made up wit ha ball and socket joint. This made for easy removal of the exhaust system. I'm glad I did it 6 years ago because I have had mine off every winter since for upgrades. I can have my exhaust off in a matter of 1/2 hour.
Old Feb 9, 2007 | 08:09 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
gordon do you have picture of this? thks bob
Old Feb 9, 2007 | 08:16 AM
MN80Vette's Avatar
MN80Vette
The guys at my favorite exhaust shop said they prefer to make one out of regular pipe because it is easier to cut and install the H after the two main pipes are up rather than install a part of the H on each pipe and try to cut & insert the cross pipe.
HOWEVER, a premade balance pipe might look nicer where the cross pipe joins the exhaust pipes. Like these:
http://store.summitracing.com/partde...5&autoview=sku
I don't know for sure though because I've never seen one of these. You can also buy just the cross pipe ends, but the exhaust guy still needs to cut the main pipes.:
Old Feb 9, 2007 | 08:19 AM
Gordonm's Avatar
Gordonm
Here you go. One side is flared out and the other side flares out then is curved back in. The two clamps hold it all together.
Old Feb 9, 2007 | 08:57 AM
shafrs3's Avatar
shafrs3
I just finished a 3" system using ball and sockets to split the system, they don't leak a bit and allowed a few degrees of misalignment lengthwise. I wish I had also used them on the header collectors.
Old Feb 9, 2007 | 09:43 AM
TopGunn's Avatar
TopGunn
I did a similar thing with mine, my "H" is welded to each of the pipes and the pipes are joined to the exhaist pipes with band clamps just in front of the "H". It works great, the whole thing comes out as a unit, I've had it out 3-4 times. I think Gordonm was the one who gave me the idea.
Bill
Old Feb 9, 2007 | 10:00 AM
sly vette's Avatar
sly vette
By the way...I heard this from an old tuner. He said when you install a crossover pipe, you need to know where to put it. He suggested that with the old exhaust still intact and the exhaust cold, get under the car and with a wax crayon mark the pipe from collector to axle. Then start the car and watch where the crayon starts to melt first. That is where you want to put the crossover pipe! Something to do with resonance.
Old Feb 9, 2007 | 10:39 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
On a conventional car, you want the crossover 18" behind the collectors. In the C3 that's impossible though
Old Feb 9, 2007 | 10:53 AM
okinawa86vette
The exhaust shop I went to is no stranger to Corvettes...like the owner's 78. He said ideally you'd want it where you said, about a foot and a half behind the collectors. Mine is about 6 inches behind the crossmember, right below the front of the driveshaft.
The shop mandrel bent the tube so it has a very shallow U shape. He said they do that to give more room around the driveshaft if I have to remove it. The try to do that and still not sacrifice ground clearance. It hangs about the same as the header collectors do.
They did a really superb job on it, with the ends cut to fit around the pipe. Even before he welded, there was no gap between the primary pipes and the crossover.
What's nice, is that there was a very noticeable improvement all the way around for only about $50. The whole trip cost me $100, including the H pipe, 3 or 4 welds, some other small weld touch ups and a couple new clamps.
C
Old Feb 9, 2007 | 11:27 AM
Red 69's Avatar
Red 69
My H-pipe crossover is located about 18 inches behind the collectors and works as intended, but at an inconvenience. The exhaust and crossmember needs to be dropped as a unit. This is an infrequent event, so I can live with it. Since the photo was taken, the system has been covered with exhaust wrap which keeps the interior and underhood temps down.
[IMG][/IMG]
Old Feb 9, 2007 | 09:31 PM
bobs77vet's Avatar
bobs77vet
thks
Old Feb 10, 2007 | 09:40 PM
blctalon's Avatar
blctalon
Cool. I just had the exhaust done today on my 78. I had 2.5" duals, H-pipe and Super 40s installed. Exhaust guy made the h pipe out of regular tube. Overall he did a nice job on it, I think.
Sounds pretty deep and mean. Definately quieter in the cab than the old Delta 40s on my 355ci truck. I'll try to take some pics or videos tomorrow with sound. I know alot of people ask questions about these muffers and how loud they are. Now I need to replace my throttle cable so the secondaries open all the way on the demon.
To H pipe results
