new 72 vette owner
Old Feb 10, 2007 | 10:31 AM
Tim Gensel's Avatar
Tim Gensel
8th Gear
Default new 72 vette owner
Just bought a 72 vette with aledgely 63,000 miles. Just put new seals in the rear since there was a lot of grease and grime around the rear. now I seam to have a noise in the rear when I'm of the gas or cruising with a light pedal. Donlt know if it did it before because I live in the north east and only drove it a few miles after I got it and the weather turned bad. also after my drive this am I noticed some smoke when reved up parked but none noticed when driving it hard (Valve seals ?Clevite 216-1021 seals were in a box in the car when I got the car but not sure how the install on the stem (pressed on or just pusjed on the guide stem?)
I would appriciate the help
Old Feb 10, 2007 | 12:33 PM
GTR1999's Avatar
GTR1999
Tim,
When you installed the new pinion seal did you mark the nut where it was before removing it or did you just remove the nut yoke, and replace the seal and tighten the nut tight?
Valve seals will cause it to smoke on start up.
Where in the NE are you?
Old Feb 10, 2007 | 12:54 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Congrats on the new purchase. Like everyone else with a new ride, you'll be chasing down odd noises and other issues for the next few months- Good Luck!
Old Feb 10, 2007 | 03:58 PM
Tim Gensel's Avatar
Tim Gensel
8th Gear
I marked the nut but lost the mark in the process but I think I got it close!
Old Feb 10, 2007 | 04:01 PM
Tim Gensel's Avatar
Tim Gensel
8th Gear
I'm not to far from Wilkes Barre Pa
Old Feb 10, 2007 | 07:42 PM
markdtn's Avatar
markdtn
You really need to replace the crush sleeve when you replace the pinion seal. Did you change the diff oil at the same time?
The smoke sounds like valve seals. Not an impossible job. Need a spring compressor and a way to keep the valves closed while you change the seals.
To new 72 vette owner
