! NEW "corrected" HEI cap !
Old Feb 11, 2007 | 12:47 PM
jackson's Avatar
jackson
Default ! NEW "corrected" HEI cap !
You know how the plug wires cross all over on HEI caps & don't make for a clean install? We've all seen the "crossfire" cap but those often didn't perform well. Here's something "new":
Was browsing new Accel catalog for other info & stumbled on this. Accel is now making a "corrected" cap to address the plug wire jumble ... has cyl 1357 on driver side of cap & 2468 on passenger side ... clean. These for large HEI that has coil in cap.
Accel P/N
8138K (black)
8138R (red)
8138B (blue)
8138 (plain ol' accel tan)
Dunno how these new corrected caps from Accel perform? ... but for years their other caps have been fine.
Old Feb 11, 2007 | 01:26 PM
bluthundr's Avatar
bluthundr
Nice find! I may have to ****** up one of those
Old Feb 11, 2007 | 05:51 PM
sly vette's Avatar
sly vette
Finally!!!!!!!
Old Feb 11, 2007 | 08:52 PM
LannyL81's Avatar
LannyL81
Checked Summit...but caps must be new as they(Summit) does not have an on-line price for them. Has anyone called in to have them add these part numbers?
Old Feb 12, 2007 | 12:20 AM
tigers123's Avatar
tigers123
Default jegs has them
http://www.jegs.com/webapp/wcs/store...64131_-1_11565
Old Feb 12, 2007 | 02:07 AM
sperkins's Avatar
sperkins
Man that's cool.
Old Feb 12, 2007 | 08:18 AM
MN80Vette's Avatar
MN80Vette
The description didn't explain where the correction is made. There's got to be some conductors inside the cap or something. Wadda' ya think?
Old Feb 12, 2007 | 08:45 AM
Bangkok Dean's Avatar
Bangkok Dean
They look good but I think you will have a slight miss.
Old Feb 12, 2007 | 08:46 AM
sperkins's Avatar
sperkins
No conductors. They re-route the terminals inside the cap.
Old Feb 12, 2007 | 10:44 AM
bluthundr's Avatar
bluthundr
Found them for $45.98
Tan - http://www.performancecenter.com/aut...0/ACL8138.html
Blue - http://www.performancecenter.com/aut.../ACL8138B.html
Black - http://www.performancecenter.com/aut.../ACL8138K.html
Red - http://www.performancecenter.com/aut.../ACL8138R.html
Old Feb 12, 2007 | 11:37 AM
bozzman3's Avatar
bozzman3
I tried to order this cap from Summit and they said they did not have them and they were discontinued.I said its a new part # how can it be discontinued?Summit said there is a patent infringement going on with Accel and the inventor?This was about 6 months ago.
Old Feb 12, 2007 | 03:49 PM
Blue Juice's Avatar
Blue Juice
These aren't new. There is a picture of a small-block with a similar cap on the front of an old Smokie Yuick tuning book I have.
I asked about them at a tuning shop when I was on vacation in Canada, and apparently there is a problem because the conductors have to cross over inside the coil, and if using a high voltage ignition there is good chance of arcing and burning within the cap.
Maybe this has been solved, but I'm just passing on information I was given
Old Feb 13, 2007 | 07:21 AM
jackson's Avatar
jackson
These Accels are new ... the old cap you speak of is probably based on the problem crossfire cap I reference in initial post ... old crossfire is a modified stock cap & often had performance problems. These Accel caps are new and designed from scratch to change firing order. Still ... I dunno how the new cap performs because it's ... NEW!
Old Feb 13, 2007 | 07:54 PM
adam's Avatar
adam
They have had 'crab' style caps that plug on and reroute the wires.
I almost bought one, but it seemed to say that it was only for MSD applications...
They are pretty proud of those things at $65. It does look better than
routing wires around and under the HEI to get them straight...
Old Feb 13, 2007 | 08:27 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
thats sweet next time i need a cap thats the way i'm going
Old Feb 13, 2007 | 10:57 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Do they make them for the small-base computer-advance HEIs?
Old Feb 13, 2007 | 11:01 PM
Big2Bird's Avatar
Big2Bird
The proof will be in the pudding.
To ! NEW "corrected" HEI cap !
