need help with scr dcr
Old Mar 2, 2007 | 10:21 PM
  #121
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by King Lear
Yes and no, niether calculator is different, they both use the same math
to figure dcr, so that much we know is correct.
1). The empire net uses seat timing (advertised duration IVC most cam cards show this as .006 or .004 timing) the kb uses @.050 duration IVC+15.
2). If you entered in the @.50 timing IVC +15 into the empire calculator as your intake closing point instead of the seat timing you will come up with what the KB calculator shows using the @.050 IVC+15 method as I showed above.
3). Now flip it, enter in the seat timing(.004 or .006) IVC into the KB calculator instead of the @.050 and it will show you what the empire calculator shows you with seat timing IVC.
Now, knowing that the math is the same:
KB uses @.050 timing IVC +15
Empire uses .004 or .006 IVC
I talked with the Crane tech and he claims that with there cams you will come up with a more accurate DCR using the .050+15 timing reference then the advertised duration.
So niether calculator is more right then the other it is up to you to input whichever IVC timing point you think is correct.
The real way to solve this is for someone still building there engine with a cam degree wheel to measure the ACTUAL intake valve closing point and see which is closer the adv duration or the @.050 +15.
I believe the issue with the KB calculator is that the .050 + 15 doesn't take into account varying ramp rates.
Old Mar 3, 2007 | 05:29 AM
  #122
King Lear's Avatar
King Lear
Veteran
The Empire does not either, it goes straight off your cam card, I agree but does anyone? have the ramp rate included on the timing card? No! The ramp rate is a guess at that? If someone did I would be a bit skeptical. The rockers change the ramp rate! None of the dcr calc's take into account for the rockers which totally change the cam ramp rate and the internal boost signals sent to the carb.
Where is Dave Vizard when you need him?
Old Mar 3, 2007 | 10:21 AM
  #123
63mako's Avatar
63mako
The ramp rate will vary with the lobe profile. The .050 plus 15 is a guess to get to the intake closing point. The actual closing point is not a guess.
Old Mar 3, 2007 | 07:46 PM
  #124
King Lear's Avatar
King Lear
Veteran
I agree but the only way to know for sure is to take a cam wheel and measure it, in my opinion. After talking to the Crane guy, he said quote"well the advertised duration timing is just an estimate that changes, the @.050 is much more accurate".
Old Mar 3, 2007 | 08:54 PM
  #125
63mako's Avatar
63mako
With everything you are saying! But the .050 plus 15 to get to the actual closing point would vary drastically depending on the lobe profile. For example if that number is accurate on a mild .450 lift hydraulic flat tappet cam it would be way low on a .700 lift solid roller due to a steep ramp rate in comparision to the hydraulic. Using the actual closing point is the way to go and as you said a degree wheel is probably the best way to find that point.
Old Mar 4, 2007 | 04:07 AM
  #126
King Lear's Avatar
King Lear
Veteran
yep, I am with you, a wheel is the only way to find out for sure in my opinion. I am getting ready to build a new engine for the vette and put the one I have in my 03 Jeep. I plan to build a torque monster beast but I might build a big HP motor instead. I have not made up my mind!!!!!
Old Mar 4, 2007 | 04:29 AM
  #127
King Lear's Avatar
King Lear
Veteran
If you want to let go of that 63 split window then you know where to call!!!!!!!!!!!!!!!
I think that is a really ugly car and I am just willing to take it from you to help you out! After all, it is a brotherhood and all! LOL, I will take the C2 from you though if it is a problem!!!!!!!!!!
Old Mar 4, 2007 | 07:48 AM
  #128
dmaaero's Avatar
dmaaero
There you go 63 mako, a buyer for your heads and you don"t even have to take em off your car!!!!!
Old Mar 4, 2007 | 11:31 AM
  #129
63mako's Avatar
63mako
I know it is pretty ugly, but it has grown on me. Kind of like owning a Pug or a bulldog. They are ugly but you like them anyway. At this point it is taking up both bays of my 2 car garage for the last year so my wife would love to see it gone.
Old Mar 4, 2007 | 06:41 PM
  #130
King Lear's Avatar
King Lear
Veteran
LOL, I was just messing around, I would give up a nut for a 63 split window! that is my dream vette!
