Thanks to D-boy I am posting this picture for help. Does my 68' heater core get attached to A) and D) or B) and C)? There was a small bypass hose attaching B) and C) but I removed them to attach to heater core....was I right or wrong?
I am no 68 expert, but I will try to help. On the big block motor the Bypass hose from B to C stays. The 5/8" hose goes to the A, and the 3/4" hose goes to D. Make sure your hoses have factory 90* ends on one end where they connect to the heater core.
My heater core has the larger line on top and the smaller on the bottom. I guess large being into from the intake and smaller out of...going back to the water pump...great!
The smaller fitting/ hose goes to the intake 5/8"
This is the supply
The larger fitting/ hose goes to the pump 3/4"
This is the return.
