next problem
Old Feb 12, 2007 | 12:51 AM
lorijones's Avatar
lorijones
Default next problem
New light switch installed. When the car is running and I turn th ehead lights on not only does the head light door open but my wiper door also opens.....why?
Old Feb 12, 2007 | 10:19 AM
Durango_Boy's Avatar
Durango_Boy
You may have the vacuum tubes on backwards.
Old Feb 12, 2007 | 10:01 PM
Ray Y's Avatar
Ray Y
Is the only change you made, the headlight switch?
Were the lights and wipers functioning properly before you replaced the headlamp switch?
If yes, I agree with Duragno Boy.
Did you disconnect and reconnect any of the override swithces during the headlamp switch change out?
If yes, recheck these connections.
To next problem
