FelPro gasket set ??
Old Feb 12, 2007 | 11:36 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default FelPro gasket set ??
Found this FelPro gasket set :
http://cgi.ebay.com/ebaymotors/Fel-P...mZ180019663183
Are the included head gaskets ok for a 383 with alu heads or should I get different head gaskets ? I heard good things about the Perma Torque gaskets, not sure if these are the ones in the kit ???
Old Feb 12, 2007 | 11:41 PM
Les 94 Comp Yellow's Avatar
Les 94 Comp Yellow
I would check with the manufacture of the heads for there choice. I just rebuilt my 383 and with the alum heads I have I used fel-pro #1003.
Old Feb 12, 2007 | 11:53 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Thanks, I'll call the seller tomorrow and ask what # gaskets these are - as long as they're fine for aluminum heads I guess it doesn't matter what you use
I think I read that these PermaTorque gaskets don't need to be re-torqued (well, that's why they call them "perma torque" I assume)....
At $110 I might better buy the gaskets separately.....
Old Feb 13, 2007 | 09:46 PM
Les 94 Comp Yellow
it really does matter which gaskets you us. Some are thicker or thinner than others and will change your Compression and clearences with the pistons and valves and heads. They also have to be matched to the bore size. It would be advisable to check the specs you need with your heads and pistons and cam ( for valve clearence) with the head manufacturer. The cost of different gaskets could be very small to compare with rebuilding the engine a lot sooner than you planned on.
To FelPro gasket set ??
