removing leafs from rear pack
Old Feb 12, 2007 | 09:46 PM
Hotrod406's Avatar
Hotrod406
Default removing leafs from rear pack
I need to lower the back of my 71 but I can't use longer bolts because of wheel interference. I guess there are three options. Fiberglass spring, de arched stock spring, or remove a couple leafs. The spring is not original and is not sagged. The back of the car is 28.5" with a 25.5" tire. I want to go down 3 inches.
Fiberglass springs are expensive so I would prefer to avoid that. Any suggestions?
Old Feb 12, 2007 | 10:10 PM
bluthundr's Avatar
bluthundr
I would say removing one or two of the small leafs out of the pack would be a good cheap (free) option. I have a worn out 76 spring you can have if you want
