Deck Height
Old Feb 13, 2007 | 09:44 AM
SoCalErv's Avatar
SoCalErv
Army
Default Deck Height
Can you make a measurement of a bare block to determine the deck height or do you need the pistons installed for an accurate measurement?
Old Feb 13, 2007 | 09:52 AM
bashcraft's Avatar
bashcraft
Without the crank, rods and pistons installed, there's nothing to measure to.
Old Feb 13, 2007 | 10:08 AM
sperkins's Avatar
sperkins
You'll need to assemble the bottom end. Move piston to TDC, and measure the distance between the flat top surface of the piston (not the top of a dome or the bottom of a valve relief) and the top of the cylinder. Enter a negative number if the piston's flat surface sticks up past the top of the cylinder. At TDC the piston will "rock" so be careful in your measurements.
Old Feb 13, 2007 | 10:39 AM
jackson's Avatar
jackson
Stock sbc deck is speced at 9.025" ... that's measured from centerline of crank to top of deck. Piston height at TDC (stock varies ~ 0.045" ~ 0.025" down in hole below deck @ TDC) ... that's measured from piston crown to top of deck ... as in sperkins' pic.
If you KNOW the piston's compression height or distance, KNOW stroke, KNOW rod length and KNOW piston height in bore at TDC (aka deck clearance) ... you can calculate what the deck height is.
Old Feb 13, 2007 | 10:43 AM
bashcraft's Avatar
bashcraft
You can calculate what it "should be". In reality, it'll probably be slightly different.
Old Feb 13, 2007 | 10:50 AM
Twin_Turbo's Avatar
Twin_Turbo
sperkins where did you get that nice aluminium fixture?
Old Feb 13, 2007 | 10:59 AM
jackson's Avatar
jackson
Shy of insignificant oil clearance ... If you KNOW dimensions I listed, the calc will be dead on the $.
Machinists routinely measure deck height of empty block. Clamp a straight, true round bar in mains between M1 & M2 ... measure plumb & square from deck to bar ... ADD 1/2 diameter of bar ... for sbc350 the MB housing bore diameters are about 2.641" ... for sbc400 they're about 2.841". Don't make any sine error and it'll be dead on the $.
-edit- ADD
Old Feb 13, 2007 | 11:29 AM
sperkins's Avatar
sperkins
Pic stolen from someone else's photobucket acct.
Old Feb 13, 2007 | 11:40 AM
jackson's Avatar
jackson
TT ...YOU can probably make one. http://www.starperf.com/tabloid/page_127.htm has deck bridge (comes without dial indicator; use yours)
magnetic P/N REN.67970 about $37
non-magnetic P/N REN.67980 about $28
Old Feb 13, 2007 | 03:23 PM
Twin_Turbo's Avatar
Twin_Turbo
I have a home made TDC tool that i use and flip around for use w/ feeler gauge but this is a lot nicer, then again, I could also drill a hole in my present TDC tool...but then not even 40$ for a new tool hard to argue with that.
Old Feb 16, 2007 | 11:29 PM
SoCalErv's Avatar
SoCalErv
Army
Ok the piston compression height is 1.561
Rod length is 5.7
Stroke is 3.48
How do I get the crank throw radius for a 350? With the above information, IN THEORY, I can sum them and subtract from 9.025 and get the deck heught, correct?
Old Feb 16, 2007 | 11:40 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Rod length is 5.7
Stroke is 3.48
stock stroke is 3.480"
1/2 stroke is 1.740"
1.740+5.700+1.561 = 9.001
If your block is not decked then the piston top (at TDC) should be .024" below the deck surface
Old Feb 16, 2007 | 11:43 PM
SoCalErv's Avatar
SoCalErv
Army
Your a genius but I believe it has been decked once, so as a gestimate subtract .012 from the previous post's deck height?
Old Feb 17, 2007 | 12:12 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
genius ? nah... learned my engine stuff here on the forum..... I know enough to be dangerous I guess....
Measure how far the pistons are below the deck, then you know what was removed from the stock deck height 9.025"
Example: Your piston is .010" in the hole means your deck height is 9.011" (that's given a 3.480" stroke, 5.700" rods and pistons with compr height of 1.561")
Old Feb 17, 2007 | 12:58 AM
Bob3700's Avatar
Bob3700
Default Tolerances!
Doing the math and adding up the "Listed" dimensions will give you a theoretical deck height.
What are the tolerances that the rods, crank, and pistons are manufactured to? That is the unkown. The fixtures and gauges to measure all these components to that degree don't come cheap!
Is the rod actually 5.700 or is it 5.705? The next rod is 5.710? Stock rods have a production tolerance, as do the pistons. Once all these components have been machined to a specific dimension, then you can add the numbers up and get a deck height.
That is why you actually '"Measure" each individual pistons on their respective rods to determine the actual deck height.
RGDS
Bob
Old Feb 17, 2007 | 08:33 AM
L88Plus's Avatar
L88Plus
My local machine shop runs a 3-axis CNC machine. They can fasten a block in it, zero the machine (by the way, the dowel holes in the deck of big blocks are the measurement/location points), then measure it to .0001. If the block has been decked, the stamped numbers will be gone (or mere shadows of their former selves). In order to determine if yours needs to be decked, assemble the block with pistons at all 4 corners, then measure how far the pistons are down in the hole. Generally, if you're off more than about .002 - .003 on one side, you'll need to have the block decked for a performance engine.
To Deck Height
