TRW Rear Spring
Old Feb 13, 2007 | 10:29 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Default TRW Rear Spring
I've got a TRW spring on the rear of my '76 that's about 20 years old. I noticed that the ride height has dropped an inch or so and that I've been bottoming out in the rear. Do these composite monosprings wear out or can I just raise the rear by raising the spring bolts on each end to get me back inlto specs with ride height and eliminate the bottoming out?
Old Feb 13, 2007 | 11:15 AM
rosslato's Avatar
rosslato
i've had mine about 15yrs & haven't noticed any dropping, i'm even adding 10"bolts to lower it an inch. yes u can raise it by tightening the spring bolts
Old Feb 13, 2007 | 11:16 AM
Durango_Boy's Avatar
Durango_Boy
I started looking into a TRW spring because they were so cheap on Ebay. I came to find out why. The TRW spring was know for just snapping with no warning, and there you would sit on the side of a road with a buster rear spring. I wasn't keen on that and now I understand why they were so much cheaper than any other brand.
Old Feb 13, 2007 | 11:33 AM
Big2Bird's Avatar
Big2Bird
If it has dropped 1", it must be fatiguing. As with any dynamic part, it must have some failure point.
To TRW Rear Spring
