Pulling mtor
Old Feb 13, 2007 | 12:39 PM
Merlinhaggard's Avatar
Merlinhaggard
Default Pulling mtor
Im pulling my mottor and dont see how to detatch the clutch braket. Never messed with a manual. Searched posts and couldnt find. Please help. Do I have to pull the whole assy out?.
Old Feb 13, 2007 | 12:47 PM
Binnie77's Avatar
Binnie77
Loosen the nut on the 'Z' shaft at the frame bracket. The nut is 9/16" and may have a lock tab over it if it is original or never dismantled. You can then shove the shaft up out of the bracket and then pull the 'Z' shaft off the ball pivet bolted to your block. You can just let the assembly hang there or tie it back away from your engine while you do the exchange.
Old Feb 13, 2007 | 02:09 PM
Merlinhaggard
Perfect, thanks.
Old Feb 13, 2007 | 03:06 PM
GaryS's Avatar
GaryS
I don't know if you have ever pulled an engine before but if not, spend the $$ and buy the book "How to Rebuild Your SB Chevy." It gives a detailed procedure with step-by-step instructions, including photos in many cases. It is so easy, even a Cave Man can do it!
Gary
Old Feb 13, 2007 | 03:48 PM
Merlinhaggard
Gary
Built a few, just never pulled a standard. Im not rebuilding this BB though. Just gonna clean it up and rebuild the front end.. Thanks..
Old Feb 13, 2007 | 09:52 PM
Racer11's Avatar
Racer11
I noticed this topic and I will need to pull my engine at a later date.
Is it best , or should I pull the engine with or without the transmission attached (auto). I need to rebuild the trani only at some point in time, and if that is the case can I pull it out and leave the engine in...
Old Feb 13, 2007 | 10:40 PM
jcswm's Avatar
jcswm
Use the Clutch BEFORE you pull the motor....
Leave the clutch connected untill everything elese is done, engine on a cherrypicker, engine jacked up above the motormounts, Transmission supported on a Jack. Then USE the clutch to seperate the engine/Transmission..... THEN remove the linkage!!!
To Pulling mtor
