keyless entry & antiteft experts, I need hepl!
Old Feb 14, 2007 | 11:51 AM
jerome1979's Avatar
jerome1979
Default keyless entry & antiteft experts, I need hepl!
i have a 79 corvette with stock antiteft and door lock,
i want to connect a keyless unit, some advice will be great!
i would like to active antiteft system by keyless system i place of key lock switch!
i would connect window roll up wire also!
tu sum up i want to connect all i can !
Old Feb 14, 2007 | 12:04 PM
sly vette's Avatar
sly vette
Jerome,
Don't apologise for your English you're doing fine!
However I do not understand what information you are looking for, considering that you have the installation instructions.
I will be glad to help you if I can, but at this point I'm not sure what you are asking for help with.
Old Feb 14, 2007 | 12:18 PM
jerome1979's Avatar
jerome1979
thanks about my english :o
i have instruction but i'm not very good in electrical problems, i think i need to install some diode but where ?
and probably a bi-stble relay to activate anti-theft because actually it's a switch and i don't want to drain my battery with a simple relay.
so drawing or advice will be very cool, but before making anything i will post picture of schemas for verifications by C3 electrical experts!
Old Feb 14, 2007 | 12:57 PM
spedaleden's Avatar
spedaleden
I handed out my repair manual to a friend but I know the green wire from the drivers door will disarm your factory alarm. You can activate the factory alarm by locking the door with the key or locking the door with the power door locks on drivers door. I am not sure if you can arm the system with that green wire. Your door locks are reverse polarity so you have to hook into the slave wires.
Let me see if I can find the factory color codes
Old Feb 14, 2007 | 01:47 PM
jerome1979's Avatar
jerome1979
Old Feb 14, 2007 | 04:25 PM
spedaleden's Avatar
spedaleden
Jerome great job.
I think the color codes for 79 are the same as 80
Your slave wires are Blue and purple/Black from right door switch. Test each of these wires. A test light will show you which wire is hot in lock and unlock. These are the wires you cut. The alarm wires yellow & yellow/black go toward the power door lock switch. The alarm wire white & white/black go toward the actuator in the door.
Old Feb 15, 2007 | 03:58 PM
jerome1979's Avatar
jerome1979
still lost in my diagram
and more i read more i'm lost!
i even have doubt about how to activate anti-theft system
To keyless entry & antiteft experts, I need hepl!
