New carburetor recommendations ?
Old Feb 14, 2007 | 05:26 PM
MassaRusty's Avatar
MassaRusty
Default New carburetor recommendations ?
I am looking to buy a new carburetor for my 71 vert with a base 350. I would like something that will work with very little extra tuning. I am somewhat carb-retarded. I wouldn't want to have to change anything more than just jets. I have been considering the following carbs.
Holly street avenger 670 cfm
Holley (#0-80457s) 600 cfm
Road demon 625 cfm
Edelbrock (1405 or 1406) 600 cfm
I have been leaning away from the edelbrock because of what I have found looking for their tuning kits. I don't want to buy a kit with just a few jets because I would end up buying multiple kits just to get it right. With the holley I saw that you could buy a large assortment of jets for a decent price. I thought that these same jets would work with the road demon if I understood correctly. I have an edelbrock performer manifold that this will go on. The car is just a stock driver, I am not looking for the maximum performance. I am looking for reliability and ease of installation.
Any opinions would be appreciated along with what else I would need to go with the carb (AT kickdown stuff).
Please no quadrajet comments. Thanks.
Old Feb 14, 2007 | 05:36 PM
OregonVette80's Avatar
OregonVette80
You're going to get 100 different reasons. But, if you want a carb which really does "just bolt on" with little or no tuning let me suggest this: I did the research last August & after speaking with both Vette shops here in Portland, they both agreed with my research:
Edelbrock, Performer 1406 600 cfm
Zora Duntov, "The best ever."
Larry Shinoda, "A'hem...My favorite is the 1980."
Old Feb 14, 2007 | 05:56 PM
marshrat99's Avatar
marshrat99
Holley 670 Street Avenger here for about 3 years and no complaints. You'll need to get a throttle cable adapter and I'd recommend the electric choke.
Lars recommends increasing the jets sizes however. Since I've just installed headers I'm taking his advise. Do a Forum Search for the recommendations.
Old Feb 14, 2007 | 05:57 PM
a1sensei's Avatar
a1sensei
If you want an Edelbrock performer I'll sell you mine, it's sitting in a box in the garage (ask me why). Your stock Q-jet is the best carb for the car and will probably work perfectly as set up (rods and jets) from the factory. Rebuild the rochester, otherwise you are down grading. God bless, Sensei
Old Feb 14, 2007 | 07:40 PM
Big2Bird's Avatar
Big2Bird
Old Feb 14, 2007 | 09:58 PM
Little Mouse's Avatar
Little Mouse
Never had anything but a holley or QJ, but of the carbs you listed
I believe I would go with the electric choke 1406 edelbrock or
the 670 holley avenger. Edelbrock has a complete calibration kit
for the 1406 part #1487 it has four different pairs of jets, five different pairs of metering rods and it looks like five different pairs of springs.
its not cheap around $35.00 for the kit.
Old Feb 14, 2007 | 11:02 PM
Georgia1974's Avatar
Georgia1974
I basically wanted the same as you, I had the stock 350. I went with the holley 80555C. It was a direct quadrajet replacement and 650cfm. I had to modify the accelerater linkage bracket but other than that I was very happy with the installation. I did no tuning except for the idle. The perfomance has been very good.
Old Feb 14, 2007 | 11:03 PM
ajrothm's Avatar
ajrothm
Dude go with either the 600 holley or the 670 Street avenger. Those things are not going to need anything other then a possible float adjustment, setting the idle speed and idle air bleeds.
Bolt em on and forget it. Stock or basically stock 350 doesn't ask for much.
Stay away from the junk edlebrock carbs. Stick with what GM used in the first place.
I personally would go with the 670 SA.
BTW I stuck a box stock 3310 Holley 750 vac sec on a ZZ4, set the timing to 36* and the AFR was 13.0-1 with 1 5/8" headers and 2.5" exhaust. Needs no choke to start, even in winter.
Don't over think or over tune something that doesn't need it.
Old Feb 15, 2007 | 12:00 AM
Little Mouse
Whats wrong with edelbrock carbs been thinking of trying one if
I ever end up with a stocker type engine in something.
Old Feb 15, 2007 | 12:10 AM
panchop's Avatar
panchop
edelbrocks and carters work just fine for me.
Old Feb 15, 2007 | 10:03 AM
ESU's Avatar
ESU
California legal carb, runs very lean, a carter afb re-pop, not very tuneable. Had one didnt like it, Lars rebuilt my q-jet, much better now.
ESU
Old Feb 15, 2007 | 12:16 PM
Kid Vette's Avatar
Kid Vette
Here's another option:
Holley Model 4165, PN 6210 with a Weiand Action +Plus, PN 8004 intake manifold. Its all a direct bolt on with stock choke, fuel line and air cleaner.
Old Feb 15, 2007 | 12:30 PM
Little Mouse
Just going to the parking lot car shows seems like I see more
Edelbrock carbs on street cars then anything else they must
have the public fooled. I like holley but I thought if I had the
chance might try an edelbrock.
Old Feb 15, 2007 | 12:43 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
i bought the Edelbrock 1405 with manual choke - runs right out of the box, no problems whatsoever.... $240 at the local "Zone"
Old Feb 15, 2007 | 01:40 PM
Gunn353's Avatar
Gunn353
I had a holley 650 DP on mine for a while, ran good and pushed out about 350hp. I went away for 2 years and the car was sent in to a mechanic (without my approval) and the jerk stripped my carb and put on an Edelbrock 750 elctric choke cuz the holley was leaking (all it needed was a rebuild...$25) Anyways, the edelbrock ran fine on it, very low maintanence, car ran fine. Took it and had it dyno'd and it was only pushing out 199hp. the edelbrock cut my power by 150 horsies! I was not happy.
SO, if you are not looking for performance or power and are just gonna be cruising around and want a low maint. carb, get the edelbrock. If you want power and performance get the holley. I personally will never use an edelbrock again...period. I now have a holley 750 vac. secondary and it out performs the edelbrock hands down and runs great.
Old Feb 15, 2007 | 02:26 PM
Kid Vette's Avatar
Kid Vette
NOT!
Old Feb 15, 2007 | 05:57 PM
MassaRusty's Avatar
MassaRusty
Thanks for all of the comments. I have decided to go with the holley street avenger.
To New carburetor recommendations ?
Old Feb 15, 2007 | 06:17 PM
Dr.G's Avatar
Dr.G
I have a 670SA in the box if you want it send me a PM. I took if off to put on a 770 SA. The 670 was to small.
Dave
Old Feb 15, 2007 | 06:23 PM
LT4Coupe's Avatar
LT4Coupe
Are you still running the original intake manifold (spreadbore config.) ?
Found the answer in your original post.
"I have an edelbrock performer manifold that this will go on"
Old Feb 15, 2007 | 06:28 PM
OregonVette80
Originally Posted by Kid Vette
NOT!
Larry Shinoda, "A'hem...My favorite was the 1973 but I've changed my mind. It is now the 1980 with an incorrect L88 hood with 427 lettering."
I was wondering when you were going to catch that!!!!
How do you know that my name isn't Zora Duntov? It could be
-Peace
