Inline fuel filter solutions
Old Feb 15, 2007 | 11:27 PM
LannyL81's Avatar
LannyL81
Default Inline fuel filter solutions
Want to add a filter between the pump and carb on my '81. I know to stay away from the push-on rubber hose style. So what works? cutting the metal fuel line and then flaring the ends with -10AN fittings? Or is there a better method....braided hose with AN fittings?
What have you guys done that works and no leaks?
Old Feb 15, 2007 | 11:29 PM
PRNDL's Avatar
PRNDL
lars has written a paper on that very topic. I followed his instructions and bent my own fuel line and now use an inline fuel filter that I believe was original equipment on 1985 corvettes. The paper is around somewhere. One potential problem is I think a fuel line part# that he recommends using is now discontinued.
GF481, looks like this:
except I think GM went and changed that part# too!!
Old Feb 16, 2007 | 12:43 AM
noonie's Avatar
noonie
Here are a couple of choices for -6an
Have washable filters in 10 microns or 40 microns
Jegs even has similar that takes the oem qjet paper filter.
You can use your present 3/8 steel tube line and use either 3/8" JIC tube nuts (shown) or -6an nuts.
Steel line is better and cheaper than braided hose.
Old Feb 16, 2007 | 12:54 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Summit has a good selection of in-line -an fliters in various micron levels.
Old Feb 16, 2007 | 06:48 AM
guppie's Avatar
guppie
St. Jude Donor '08
Here's what I did with mine,
To Inline fuel filter solutions
