started a thread with some thoughts on aluminum brake calipers that i saw on corvette centrals web.... i have one caliper that is sucking air but no fluid leak....and sooner or later no brakes.... so i thought if i threw more money at my car..... get the picture....
the real picture is.
new calipers, rebuilt with s/s, new rotors and turned... new lines....new master...(dot5)... trailing arms rebuilt.... now the arms and calipers were new 15yrs ago but i never installed them utill 5/06....maybe they went bad?....or could it be something else?
Instead of throwing more money after it, you should throw a little knowledge at it. This symptom is caused by rotor runnout. The key thing here is, you turned the rotors. That may not have been the best thing to do. Now you need to go back and check the runnout on each rotor and get them into spec. That will solve the brake problem.
If you're thinking about aluminum calipers, check out the kits at Corvette Engineering. Keith makes a superb kit to mount Wilwood calipers to our cars.
why is turning the rotor not the best thing to do?.....only one caliper is pumping air.... thanks
Having the rotors turned is a good thing IF done right. They have to be witnin spec on runout and thickness when finished, sometimes they're half azzed and not done right. But your problem might not have anything to with the rotors. Rubber seals, when sitting for long periods of time unused can take memory of their position and begin leaking when finaly moved. Are you sure they are pumping and not just leaking? If leaking they will still suck air when you release the pedal.
The original set up was riveted together and turned as a unit. This assured that the shaft and rotor were true. Once removed, turned and reinstalled, they never are correct again. At least not without trueing them up in some way. The correct way is to do the same thing the factory did and turn them as a unit. The next best thing would be to true up both mating surfaces and match them that way. The next would be to re-position or shim the rotor to reduce the run out to a manageable level.
If you put a dial indicator on the caliper that is sucking air, you will find that it has a considerable amount of runout. You will have to take care of that before you will have any lasting brake.
the brake shop that turned my rotors did them off the car and just to clean them up...light rust....so i need someone that can turn the rotors on the car?.... man, i, am, dumb!.... Thanks!
Not dumn, just not aware of the problems. Jack the car up, support the rear suspension so that the wheels are not hanging. Remove the wheels and replace the lug nuts. Start the car and let the wheels turn. Take a look at that rotor and watch the pads. My guess, you will see them moving in and out. This is the action that causes the air pumping. Remove the caliper and turn the rotor to one of the other possible positions. Find the best position. This may mean you cant adjust the parking brake because the hole will be covered. If that dont work, you may have to make some very thin shims to go under the rotor to correct the runout. You can make them like a washer and install on the lugs where needed.
thanks for the info!... how much shim is to much? .004? .010? seems that there might be a point where i might look at some other ......Geezzz!... one thing at a time..... i'll give it a try!
Thanks!!!
Thanks for the info on how to cure run-out. I don't get air in my brake system, but I hear a squeek squeek squeek coming from one of my rear wheels when moving slowly with no brakes applied. How difficult is it to remove the rear rotors ---- complications with emergency brake workings that are all origional on my 1975. What should I watch out for when attempting this.
