oil pump
Haven't even fired it yet. From the discussion, I have decided to change back to a standard volume pump. Probably will get a standard volume GM pump. So, if you need a M77HV...let me know.
Good Luck, Wally
anyone considering replacement of their SBC pump should
be aware that in 2004-2005 there was a change to the SBC
casting. Pumps distributed since then ought to be carefully
evaluated to determine whether they are suitable for your purpose.
There is a lot of reading in the following threads from C4 Tech
SAVE YOUR ENGINE-Melling has weakened the casting on their SB and BB oil pumps
Moroso oil pumps
near the end.
My conclusion is still that there appear to be a light, medium and HD
version of the castings resellers can choose from the manufacturer.
By my reckoning, the current choices for SBC use in a performance
application are fairly clear-cut.
But I don't know the particulars about your not so stock small block
or the primary application it is used for. So perhaps your requirements
call for other solutions.
IMHO the Melling is a tight tollerance heavy duty well made pump.
Eddie
there is a lot of material there and it took a while before the haze
began to clear. Here is a synopsis.
Look at the pump leg. How wide is the casting lip where it has been
cut by the facing operation to the mounting boss? (The M55 Std Vol
pump is very narrow here, the M55HV high vol pump is wider, the
M-Select series pumps are widest.)
Is the horizontal portion of the web from the leg to the boss for the
driven shaft in the body stepped? (I've marked the image with the
Moroso p/n but I hold Melling responsible for the issue.)
If so, this is the lightest of the three castings that I am aware of
and I do not think your supplier will be able to produce an M55?
with a heavier casting.
If you feel that a std vol/std pressure pump like the M55 is appropriate
then the heavy duty equivalent is the M-Select 10553. Here is a
clip from another thread with a partial list of the M-Select pumps:
85vet that the 10553 is the dimensional equivalent of the M55. In
other words: it is a 5/8" press-in inlet, Std Vol, Std Pressure pump.
- 10553: Std Vol, 5/8" press-in inlet
- 10554: Std Vol, 3/4" press-in inlet
- 10550: 25% Vol, 5/8" press-in inlet
- 10551: 25% vol, 3/4" press-in inlet
- 10990: 25% vol, 3/4" press-in inlet, shafts extend into cover
- 10991: 25% vol, 3/4" press-in inlet, shafts extend into cover, anti-cav
Edzred72, Melling appears to make a large percentage of the
SBC pumps on the market. Pumps from other vendors appear
to be re-boxed versions of the Melling units.
The issue is that there has been a change in the castings
Mellings produces for the pumps, specifically that they
have reduced the amount of material in the leg that mounts
the body to the main cap.
The difference in price between the revised pump and the
M-Select pump is trivial - especially when you consider
that the M-Select includes a HD drive shaft. The M-Select
line consists of a variety of pumps from STD Pressure/STD
Volume 5/8" inlet units up to Hi Pressure/+25% Volume pumps
with 3/4" bolt-on inlets.
For the sake of saving $10-$20 dollars, why buy a pump that
has been built in a fashion that permits this to occur?
has since been removed)
There is also the M-Select 10552C which has anti-cavitation
grooves in addition to the features you mentioned.
A consideration to keep in mind is how shallow the oil pan is.
Features like the extended shafts, 3/4" inlet and longer gears
for the high volume versions all extend the distance the pump
hangs down from the mounting point on the the rear main cap.
The 7" RR pans on a C4 appear to reduce the pump choices.
I believe the C3 pans tend to be deeper so this may not be
as much of a factor.
