Replacing distributor, to HEI
CLICK HERE
The old points style coils circuits had a ballast resistor in line to limit current. Because the new HEI can produce much more spark energy,the primary feed will have to have a larger wire to support the draw.(and eliminate the ballast resistor)
Use a minimum of 10 gauge wire from a switched ignition source.
Cap and stow the original wires to the coil in case you ever want to go back to original..
The second one is sold by Lectric Limited, called the Breakerless SE. It requires a single wire to the coil, just like original, and uses the existing wiring that provides 6.6 (?) volts. Both use a Hall cell. I just bought one to replace my Ignitor, since I am installing new wiring harnesses, and hated to cut up a new harness to use my ignitor. The price is a little less than the HEI, but I wanted to retain the stock look and ignition shielding.
Lectric Limited can also modify a stock engine harness to allow HEI distributors, if you call them and ask when you buy the harness. I guess it all depends on how persnickety you are.
http://www.madelectrical.com/catalog/hei-1.shtml
I am extremely happy with the HEI.
I ran a dedicated 10 gauge wire from the ignition wire at the fuse block (pink).
I had a connection already in place. I picked up 2 distributor connections from Jegs P/N 55-10550 and they fit perfect.
http://i107.photobucket.com/albums/m...p/DSCF2138.jpg
