I have about 3/16" to take out across the bottom of the port. It needs to go all the way back to the floor of the intake. I am using a dremal but it is slow going. Used 6 bits to do the first port and it took about 45 minutes. Any better options out there? I don't have access to machine shop tools but have pretty much all basic hand tools.
Call me a cave man if you want,but I hand filed mine. Put the intake in a bench vise using a lift plate to clamp the intake in the vise,and hand filed with a flat file and rattail file to blend in well over an inch per port. I did two ports a day after work (spent an hour a day),and I think it came out just fine. The fear I had with power cutting is aluminum is very soft,and a lot of material can disappear with one flinch. Cutting by hand is much more controlled.(If the intake was cast iron.....different story.
Man, you are a cave man! My intake was pretty hard stuff took about 2 hours a side with the dremel just for the rough cutting. I removed the bulk of the material with a fluted bit. Key was to keep it moving. Then hit it with a dremel large drum sander and rounded the interior bottom and flattened the sides with a hand file. Last pass was going over the whole worked area with a dremel wire wheel. Feels smoother than it looks.
