diff to crossmember torque specs ??????
Old Feb 16, 2007 | 09:53 PM
cherrybombc3's Avatar
cherrybombc3
Default diff to crossmember torque specs ??????
Anyone have the crossmember to diff torque specs?
Old Feb 16, 2007 | 11:17 PM
cherrybombc3
Got em, incase anyone else needs them here they are.
Torque Specifications
Diff front mounting bracket bolts: 50 lb-ft
Diff crossmember to diff cover bolts: 60 lb-ft
Diff crossmember to frame bolts: 65 lb-ft
Axleshaft U-joint caps to diff bolts (inner): 35 lb-ft
Axleshaft flange to spindle flange bolts (outer): 65 lb-ft
Strut-rod bracket to diff mounting bolts: 45 lb-ft
Strut-rod shaft/shock mount stud: 75 lb-ft
Trailing-arm pivot bolts: 50 lb-ft
Wheel lug nuts, steel wheels: 80 lb-ft
Wheel lug nuts, aluminum wheels: 90 lb-ft
Old Feb 17, 2007 | 10:56 AM
GTR1999's Avatar
GTR1999
You're going to want to check the fit of the caps on the joint cpas as well so they are not crushed at 35 ft/lbs. If they bind up on the cap you'll have to fit them. Of course you could do as many do and just torque them as is.
Old Feb 18, 2007 | 02:41 PM
cherrybombc3
Thanks Gary, yep did that while it was out of the car. Chased all threads, pre-fit everything, per you tips. Thanks Bud!!
To diff to crossmember torque specs ??????
