no heat?
Old Feb 17, 2007 | 08:09 AM
rabiddawg's Avatar
rabiddawg
Default no heat?
well I took the 69 vette out of the garage for the monthly warm up etc.
and had the heater crankin inside.
but no heat?
blowers working and all the plumbing is hooked up?
first time I tried the heater since i bought the car last october.
One thing i do know is the previous owner was messing around in the center console area and im thinking he wired something wrong on the controls.
Old Feb 17, 2007 | 08:20 AM
Big2Bird's Avatar
Big2Bird
If you are getting air flow, I doubt it's electrical.
Old Feb 17, 2007 | 08:34 AM
79vetter's Avatar
79vetter
It could be a couple of things:
You might have a blockage somewhere that is preventing flow through the heater core. Is the cooling system full?
The temperature blend door might be binding.
Old Feb 17, 2007 | 09:16 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
How cold was it outside? Whenever I drive my cars this time of year they run so cold the car doesn't heat up. Since your heater is getting it's heat from a cool running engine it blows colder than normal air. Also you may have a faulty thermostat.
Old Feb 17, 2007 | 12:44 PM
rabiddawg's Avatar
rabiddawg
car was fully warmed up to 190 degrees
A/c works at least in summer but it could be colder.
I tested the thermostat in boiling water and it works.
where is the blend door located?
is it electrical or vacum controlled?
if its a vacum controlled door that might explain why my wiper door creeps up a bit after I shut the car off.
Old Feb 17, 2007 | 12:47 PM
Big2Bird's Avatar
Big2Bird
I believe that is usually caused by a defective check valve.
Old Feb 17, 2007 | 12:51 PM
Paul L's Avatar
Paul L
The coolant flow valve in the engine-side heater hose opens to allow flow into the heater core. It is vacuum-actuated via a small tube running from the console heater controls to the valve itself. It is likely that that tube is disconnected at the console. Or alternatively the valve is frozen/corroded shut internally.
Old Feb 17, 2007 | 01:10 PM
rabiddawg's Avatar
rabiddawg
ok ill check that next since the last owner made a mess of the center console
Old Feb 17, 2007 | 01:27 PM
Paul L's Avatar
Paul L
Vacuum checks/diagnoses can be frustrating. Another way to do it is to remove the valve and join the two cut ends of the hose with a short piece of pipe, clamp, and start engine. Without the valve in place there will be unrestricted flow towards/into the heater core and you should have heat. If not, then the core is plugged. If yes, then you can go looking for the vacuum leak or bad valve. On the latter, I believe places such as Autozone still can get access to them.
Old Feb 17, 2007 | 04:14 PM
general69's Avatar
general69
those vacuum powered water valves were only on automatics not 4 speeds.
my 69 is 4 speed and the controls are cable driven. the mixer door is behind right dash panel.
ctrain22's Avatar
ctrain22
Check the heater control valve. It is a vacuum operated switch that is in line with the 5/8" hose between the manifold and the heater core, in the engine compartment. Mine is actually mounted behid the right side louver just before the heater core.
Old Feb 17, 2007 | 04:31 PM
Disco_Mike's Avatar
Disco_Mike
I had a problem where the heat connector cable attachment at the blending door was broken. (behind the glove box)
Old Feb 17, 2007 | 04:45 PM
Acro74's Avatar
Acro74
Make sure the hoses are connected correctly. Had a friend that went 2 winters with no heat, would get a little warm but never hot. Finally he figured he would look into it and he had the hoses reversed
Old Feb 17, 2007 | 05:31 PM
Paul L's Avatar
Paul L
Acro,
That's pretty hard to do. One is 5/8" and the other 3/4".
Old Feb 18, 2007 | 08:36 AM
rabiddawg's Avatar
rabiddawg
lol id say but with a bit of determination and a little grease im betting he did it.
I wonder if he thought the 3/4 line went on the 5/8s real easy and not the other one?
Old Feb 18, 2007 | 09:55 AM
goinbroke's Avatar
goinbroke
Here's a thread from the archives where the water inlet valve is being discussed.
http://forums.corvetteforum.com/show...+control+valve
Old Feb 18, 2007 | 10:02 AM
SmokinBBC's Avatar
SmokinBBC
I think AC cars had the water valve on 4 speeds as well. Mine a a '70 with AC and it has the valve.
To no heat?
Old Feb 18, 2007 | 04:09 PM
rabiddawg's Avatar
rabiddawg
im sure mine has it
Old Feb 18, 2007 | 04:28 PM
noonie's Avatar
noonie
After you have eliminated your valve as a problem:
You can just feel the two heater hoses, they should be almost the same temp-hot or check with an a/c vent thermometer held against them.
Then
You may want to check the coolant flow thru the heater core.
Disconnect the heater lines at the manifold and waterpump.
Connect a 4 ft long 5/8 heater hose to a garden hose and run into a 5 gal bucket noting the time it takes to fill.
Connect the garden hose to the 5/8 line of the heater core and put the 3/4 outlet line in bucket and time that one.
If the time is different the heater core is plugged and needs replaced. They cannot be flushed out properly.
It is a common problem.
Also a 195° thermostat is usually necessary for good heat.
Old Feb 18, 2007 | 04:38 PM
Disco_Mike's Avatar
Disco_Mike
my 79 has AC and 4 speed. It also has a vacuum cut off valve for water supply to the heater core.
