need help identifying
Old Feb 17, 2007 | 02:59 PM
brookman's Avatar
brookman
Default need help identifying
We (me) just bought a 76 L82 for my son.
I am trying to determine if the engine is the right one for the car.
I also need to find the model/serial for the carb so I can get a rebuild kit.
The numbers I have found on the block are :
in the rear on the drivers side 29 GM 397001
front on the passenger side V0104CKL There are actually two sets of numbers one little set one big set. The big set is what is above. I am having a hard time making out the small numbers.
On the carb - all I could find is 7045504 TM 2954 It is a Rochester
Thanks for any assistance
Old Feb 17, 2007 | 03:43 PM
jotto's Avatar
jotto
V = Flint plant,
01 Month = January
04 Day =4th
CKL ?
L82 codes for 76 are CKC and CHC according to my book.
Carb is a 1975 Chevy, California carb with Auto trans.
CKL code poss
1973 350ci tur hydro, Calif - F A B
1975 262ci - Nova/Chevelle/Monte
Old Feb 17, 2007 | 03:44 PM
dgruenke's Avatar
dgruenke
From what I found, it is either a 1973 350 or a 1975 262. I don't know how to decipher the date code, so maybe someone else can narrow it down even further.
Here is the site:
http://www.nastyz28.com/chevy-engine-code-stampings.php
Old Feb 17, 2007 | 08:11 PM
brookman's Avatar
brookman
Thanks for the assistance. The car had been in an accident and it has a salvage title. I didn't figure that the engine would be original.
Old Feb 17, 2007 | 10:07 PM
lucky76's Avatar
lucky76
I also need to find the model/serial for the carb so I can get a rebuild kit. in the rear on the drivers side 29 GM 397001
I have a 76 L48 and my engine is 3970010 (your missing the zero on the end) so you have the correct block.
My block ID is "CKW" for an L48. It's odd but I have the same carburator as you, 7045504, which I already
knew was a 75 California automatic. But my car is a 4 speed and it was sold in Mississippi,
I have the invoice. I guess that must be the replacement carb somehow.
Are your heads, 333882 ? You have to remove the valve covers to see these numbers. :
Old Feb 18, 2007 | 09:12 AM
brookman's Avatar
brookman
I searched a little and found in many places that the carb was from 75 and one place showed 75 and 76. I will see if I can clean up the numbers on the block. Thanks again!
To need help identifying
