what carb for this engine...
Old Feb 17, 2007 | 11:17 PM
panchop's Avatar
panchop
Default what carb for this engine...
took my 75 vette motor. yanked the stock heads, put on a set of small valve fulie heads, stuck an L79 cam in, put an old low rise spread bore dual plane holley manifold on it. exhaust goes threw small tube headers ,the engine pulls 20 inches of vacuum at idle. the carb i rebuilt doesn't work so good so i will just buy something new. it's going in a 72 GMC half ton in front of a TH350, with 3.70 rear set, want it for bopping around and some light towing. what carb do i need?
Old Feb 17, 2007 | 11:23 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Go to Summit or Jegs & get a Qjet. No use in anything else on that motor.
