File fit piston ring's, how big gap?
He posted the pic yesterday. It's in post #16, does it show up on your screen ?
Let's try this :
To start with, he should've posted that pic in initial post ... same issues as before ... disagreement on what's chrome/shine etc.
It's clear from the pic the rings at bottom of stack are top moly ring.
To me, moly rings are not chrome or chrome like ... their color & dull sheen look like all moly rings I've seen. I think their color & dull sheen resemble pewter or cheap silver ... or the OE grey/silver-painted urethane bumpers on my sonoma ... not like those on my 71 C3. Everyone's got their own take on what's shiny or dull. I think the paint on my truck looks ok ... next guy'll think it's dull ... another'll think it's shiny.
The piston spec link is useless without knowing his piston P/N ... probe's sbc top ring lands range about .130 -.260 ... not enough info to suggest a top ring gap since we don't know how far down his top ring is. Suggested wider 2'nd ring gap is well-documented. Suggest builder verify both ring width & depth are matched to piston.
That ring set 315-0033 is NOT DESCRIBED in the pdf ring catalog … it’s Xreffed, but not described.
Without further info, I'd follow the ring mfg spec. It's a toy, not a champ car.
I was assuming that the "shiny" ring was a chrome ring, and the "not shiny" ring was a moly ring. I was wrong!
We have all now learned that moly rings can be shiny like chrome!
These rings might not be the perfect rings for my engine.
But they will be good enough for the few miles I will drive my car.
Yesterday I filed the rings, and I manage to get them nearly perfect within the spec!
Here's my filing tools:
0.016"-0.018" gap:
BTW: The complete # is 315-0033.65 (last digits is just the bore size)
You'r right jacksson, it's a big (and expensive) toy for me, this is just for fun, if I loose a few hp, that's ok.
The most important is to see if I can build a engine!
I have never done this before, it's a really big challenge for me!
My machinist's milling maching broke down, so the deck isn't milled yet!
I have to found an other machine shop!
I took the measurement 1/2" down in the cylinders.
Moved the rings up, just to get the camera to focus....!
BTW: The complete # is 315-0033.65 (last digits is just the bore size)QUOTE]Nothing wrong w/ your filing tools ... always file inward (away from cylinder wall). Regardless of size, that number ain't described in online ring catalog you linked.
110%
