hard starting problems - Help1
Old Feb 18, 2007 | 08:56 PM
rthawk1's Avatar
rthawk1
Default hard starting problems - Help1
I am having problems starting my vette....
72 coupe...350 K engine
new Accel points and wires
New Accel coil
Mallory dual point distributor changed to electronic
I have 13.8 volts at the battery...
with ignition switch on...12.7 volts at the + side of the coil
when cranking it drops to 8+ v on the - side of the coil
with ignition switch on ....12.7 v at the alternator
with ignition switch on ... 12.7 v at the end of the coil wire going into the distributor
when checking ignition coil switching (I am notsure if this is a useful test for this age car) I register less than 50 RPMs
Any thoughts? I appreciate and thank for your suggestions
RT
Old Feb 18, 2007 | 11:29 PM
TimAT's Avatar
TimAT
I'm a bit interested in the 8 volts on the - side of the coil. The - side of the coil should go the points, or module in your case. If it was a standard points ignition, the + coil should go to the ignition and the -coil should go to the points. If a coil is backwards it will work, but be hard to start. And seeing the 50RPM on the switching circuit tells me the module is working- seeing the rotation..
Old Feb 19, 2007 | 01:37 PM
rthawk1's Avatar
rthawk1
The ignition is wired to the + side of the coil...but so is one lead (red)from the three-wire modual to the + side of the coil. The distributor modual also has a lead to ground (brown) and a lead(green) to the - side of the coil.
I feel I am not getting enough spin from the starter to turn the engine over...the rpms seem very low.
rt
Old Feb 19, 2007 | 01:41 PM
Big2Bird's Avatar
Big2Bird
Two questions.
A)Did it turn over slow before?
B)Did you take the ballast/ resistance wire out of the equation?
Old Feb 19, 2007 | 04:42 PM
rthawk1's Avatar
rthawk1
Originally Posted by Big2Bird
Two questions.
A) yes it would turn over slow...then catch fire.
B) I did not take it out of the equation....I listed what was showing on the auto meter
thanks for the questions...it helps to sort out the problem.
To hard starting problems - Help1
