Not able to use Pivot Stud
Old Feb 19, 2007 | 02:03 PM
ChuckPhillips's Avatar
ChuckPhillips
Default Not able to use Pivot Stud
Anyone that has followed my threads will know I am putting a Bastard sbc 350 in my 69 until I get a numbers matching motor. Until then, here is one of my problems. The 350 I have, and just about done with, does not have the position in the block to incert a pivot stud on the Clutch Cross Shaft, is there something out there that is a bolt on mod? or will I have to fabricate something in the mean time?
Old Feb 19, 2007 | 02:19 PM
jnb5101's Avatar
jnb5101
machine shop time.
Old Feb 19, 2007 | 02:20 PM
ChuckPhillips
Default Thought so...
really not interested in doing this.... But if I dont go this route, she sleeps for another couple years, and I cant wait that long!!! lol
Old Feb 19, 2007 | 02:28 PM
The3's Avatar
The3
I know there is a bolt on solution. I've seen it before from one of the vendors but I can't recall which one. I'll start looking.
Old Feb 19, 2007 | 02:31 PM
big_G's Avatar
big_G
http://www.sdpc2000.com/catalog/1006...-Corvettes.htm
Old Feb 19, 2007 | 02:37 PM
The3's Avatar
The3
gooood
Old Feb 19, 2007 | 02:42 PM
ChuckPhillips
Default Thank You
I contacted them and they said it was used for big block but not sure if it would work with Small Block. I would think so, it would seem to me, that the pivot point is the same for both.
Thanks for the help!
Old Feb 19, 2007 | 04:01 PM
general69's Avatar
general69
only other way i know of is either drill and tap or use a hydraulic system with either slave cylinder to push the clutch fork or they also have a system with a hydraulic throw out bearing setup(more expensive)
Old Feb 19, 2007 | 04:12 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you have a threaded hole close to there that you can use if you want to fabricate something.....this threaded hole has the plated cap screw in it above and to the right of the oil filter
[IMG][/IMG]
Old Feb 19, 2007 | 04:23 PM
ChuckPhillips
Default Thanks.
I noticed that hole, but figured it was not in line, and wasent sure how I could fabricate a brack the would stay in place using that hole... Looks like I could fabricate a bracket like the one above, it wraps around and bolts to the Bell housing.
Old Feb 19, 2007 | 04:27 PM
redvetracr's Avatar
redvetracr
I am using the Scroggins-Dickey bracket on a Dart SB....one piece of advise though....bolt it up BEFORE you drop the motor in, mine needed to be rebent, the ball stud pointed back to the door instead of out at a 90*. I also had to tig weld the ball in there wasn`t enough room on the back side for a nut.
...redvetracr
Old Feb 19, 2007 | 04:33 PM
ChuckPhillips
I was thinking it was not a easy fit. Thanks! I wish I was smart and just waited till I had the right motor to put in and do it right the first time. But I am not that smart and I want to Drive this vette, this spring!! lol
Old Feb 19, 2007 | 04:48 PM
JoeRags's Avatar
JoeRags
Just out of curiosity, where do you plan on finding a numbers matching motor if you dont already have one?
Old Feb 19, 2007 | 04:56 PM
ChuckPhillips
Default Good Question....
I am lucky to like a few miles away from a Classic Corvette dealer, he had the 350/300 motor, but dont do me any good if I have to go through all the work to make it a 350/350. Until today, I just thought it was the cam, intake and carb or something along those lines.... not the list that these guys have been talking about on here.
Old Feb 20, 2007 | 07:50 AM
BerniesVette's Avatar
BerniesVette
Aree you referring to a period matching engine instead of numbers matching?
Also, a hyd clutch would be so much easier to install on the temp. engine setup. Just a thought.
Bernie
To Not able to use Pivot Stud
