Engine Build Questions - Specifics Inside.
Cleaned
Bored .030 over
Align Bore Checked
Crankshaft ground (I don't think it needed it; they just do it)
Check/Polish rods
Fit pistons to rods
So now I've got a 355 that's been partially assembled, well greased, and been sitting bagged for about 6 years. It's in great shape still, no rust that can be found and ready to go. It was coated liberally with WD-40 before being bagged and never painted so I am probably going to disassemble it, clean it up, and paint it before moving forward.
Here's the list of parts that I currently have that I'm planning to use:
Trick Flow 23 Degree 64cc Aluminum Heads - TFS-30400001
TRW Speed Pro Power Flat Top Forged Pistons - TRW-L2256F30
Sealed Power Performance Piston Rings - SLP-E-251K030
Summit True Roller Timing Set - SUM-G6600
Fel-Pro Gasket Set - FEL-KS2600
Summit High Volume Oil Pump and Pickup - SES-3-60-08-001
So, to my point. After reading this article: http://www.superchevy.com/technical/...bolt_on_tests/ I decided I wanted to build a similar engine as what they did with the XE268H. The biggest difference will be my TF heads instead of the Holley Heads they used. I've also read a few other magazine articles that use my heads and this cam and I liked the results.
I'm planning to get this cam and lifter kit:
Comp Cams XE268H Cam - CCA-CL12-242-2
and their valve springs:
Comp Cams 417 lbs/in - CCA-981-16
I'm leaning toward 1.6:1 rockers (based on this article: http://www.compcams.com/Community/Ar...?ID=2132654598 which happens to use my heads as an example). How do I ensure they will not cause a clearance problem before I buy them?
Is there a significant difference between the Comp Magnum Roller Tip Rockers and the Comp Pro Magnum Full Roller Rockers?
I'm leaning toward the Edelbrock Performer RPM air gap Intake - EDL-7501 and the Speed Demon 750 CFM carb. Is that too much carb?
I plan to run Hooker Headers sidepipes with spiral turbo baffles.
I have no clue as to what is the best ignition/distributor setup to go with this.
I've also purchased the Keisler TKO-500 manual transmission kit that I will be putting in so basically I won't want/need any of the computer controlled stuff that was originally in the car. I've dropped all the A.I.R stuff as well.
I appreciate any time/thought you guys can put into these questions. Any additional ideas are appreciated.
The vette will be a street machine mainly and I'm happy with this cam choice; I just need to fit the other pieces together.
Thanks!!
I'd go with the cam maker's spring recommendations. They designed a spring to work with a specific cam, allowing for lift, open/closed pressures and that type stuff. As far as rockers go, the stamped steel are very durable, but the roller types has less friction. Flip a coin. You'll need to monitor the condition of the rollers a little more than the steel. As far as cam choice goes, look at what you're going to do with the car. Weekend warrior? daily driver? Or just want a little thump in the exhaust. Talk to Comp about that. Rear gears, compression, and trans all make a difference. Your pushrod choice will be dictated by your other combinations..
I feel you're right about the 600 carb being a little small. I had a 650 on a 350 that I built years ago. It was great, super low end response right up to the point it couldn't flow enough to feed the 350. I ended up with a 750. But I was also turning it to 7000 RPM too. If you're not planning on turning that high, the 650 may be plenty.
There is nothing wrong with a HEI ignition either. If you're going to change, I'd look at the MSD or Crane- something like that. I've already got the factory TI ignition, but I'm looking really hard at the Crane HI6 for both a hotter spark and rev limiter. MSD is good, but I'm not sure I like the rev limit operation of the MSD compared to the Crane. And there may be a better one out there.
You are probably close to 11 to 1. Pretty small cam for that much compression. Hey! I got a set of Brand new AFR 190 74 CC heads for sale that would probably work perfect with your setup with that cam!
I've looked online and found several compression ratio calculators but I'm just not coming up with the answers to the questions to be able to calculate it properly. I'll keep trying.
The machine shop didn't balance anything but the pistons are attached to the rods. Of course if I'm going to get the rotating assembly balanced I could get the new pistons put on at the same time. Hmm... Just depends on which I think I can sell first; heads or pistons I guess.
good everything....... 373................ 5 speed. Do I want a chance at a flat cam or some junk that sounds bad or is bad?
I purchased the same set and found them to be out of spec.
I called them and they pulled another set off the shelf and tested them while I waited on the phone..... that set was also out of spec.
I don't know where they get their valve springs, but don't assume they are good right out of the box.
I have a RIMAC spring tester...
http://www.gearheadtools.com/16365.htm
and Comp Cams #5316 calibrated spring to double-check my RIMAC.
Buyer Beware
-also- the budget gasket sets usually have a thicker ~0.040"~0.050" head gasket. If block has NOT been decked ... that combo w/64cc TF will be close to ~9.5~9.7:1 SCR. If block has NOT been decked ... A thinner victor 5746 gasket will make about ~10:1 and much better quench.
Thanks for all the replies so far!!
If you have to have comp cams - Look at the marine or computer controlled cams like the 12-268 -4 for 114 lsa 224/230 or the XM270H 112 lsa 226/236
I prefer crane cams like the 278 powermax.
With any one of these cams I would use up to 10.5 compression with aluminum heads.
. I've taken it down a notch and gotten a little more specific. Hopefully others will have a chance to chime in.
