I am looking at one and need some education on the difference engine(s).
Make me look smart
Thanks!
Teal Jewel
There were only two engines. Both are 5.7L 350s. An L48 350 would be a lower HP motor, with 2 bolt mains. The L82 350 is the higher HP motor with 4 bolt mains. There are other differences.
There were a lot of different options available as well as a lot of colors for paint and interior.
Focus more on condition of the frame and birdcage, brakes, suspension, and body. Use those criteria to decide if you want it or not.
I saw another of your posts after responding to this one originally and now understand what you are looking. Search for a thread from today on the C3 Tech/Performance titled "C3 Buyer Check List" there are some good links in the string.
The letter "L" in your VIN # means your car came equipped with the base L48 motor and an "X" indicates that it cames with the L82 Hi-Performance option. To check if your car still has the original engine in it you must look at the stamp on the engine block located right in front of the passenger side head next to the water pump, it should have the last 7 or 8 digits of your VIN # found there.
